Hood Adjustability?
Re: Hood Adjustability?
Holy cow! Is the hood bowed up in the center? I didn't think it was gonna be that bad!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
you have some issues... maybe a bad hinge or bent hood
Ed will be known as the Tiger Woods of the integration business |
Mine is doing the same thing. I think my hood hinge is worn out.
Looks like a bad hinge on the left side. Can you push the hood down on the left by the cowl to make it go down where it needs to be?
Carpe manana
![]() ![]() Join Date: Dec 2010
Grease the heck out of the hinges and see what happens - when my hoods start sitting up a bit in back this gets them level....good luck
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Thanks for all the thoughts, guys. I don't think my hinges are worn out, when I open the hood there is no play. I can't push it into place either. I guess it could be a bowed hood.
Dood, I spent hours and hours trying to get my hood down on the Blazer. Eventually I used a step drill and enlarged the bolt holes to the fender. Finally I got it. Also I used Teflon spray (very expensive) for my hinge lube. It looks passable and works awesome!
I drove my truck today. My driver's hinge is junk and the hood ain't all that great. I have to push the driver's side down every time I close the hood. I didn't think about your post until I was almost home. It was dark and rainy. I'll open and close it, without pushing the backside down and compare it to your pic. From what I understand most guys barely loosen the hinges at the fender and push the hood open so that the hinge rocks back and tighten it. That seems to help but yours may be a little excessive.
You didnt happen to put a new cowl gasket in it, did you? You wouldnt believe how bad the wrong gaskets can make a hood fit...
Does it make any differance if you put the side rubbers in?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Close the hood slowly and watch the back revets if they move you know what to do, Make sure hinges are good before changing hood
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
One of the First
![]() Join Date: Jan 2000
You can adjust hood alot easir with the fender wells removed. That is how I have done mine in the past. Before I installed hinges, I would just sit the hood on front clip on the truck. Check for warpage, look at lines. Take off, install hinges, hood again, bolt down lightly and adjust from inside fender well looking up to hinges mounts. Have rubber hammer, long flat screw driver and a 9/16 short socket and a ratchet set up from flexability. That should determine if its the hood or other body panels out of alignmnet.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#13 |
Thanks a lot for the input guys. I need a new hood anyways, so I am looking around for a new one now. There is no play or any movement in the hinge. I'll dig in and report back.
