10-16-2013, 04:06 PM | #1 |
differences in disc brake spindles between 1968 and 1972
Hello everyone! Just wanted to ask if anyone had a similar situation.
I have a 71' Chevy SWB fleetside I bought as a "Basket case" anyways after stripping and cleaning,powder coating everything, I am assembling my front steering components.well, almost. I found one of the spindles has a larger tie rod taper Compared to the other.it almost looks as if I have a mis-matched set of spindles, or two different years.the first thing that should Have clued me in on this was the different splash shield. I'm wondering if I got a '71 1/2 ton truck spindle on one side and a later model truck on the other.I'll post some pics later to show what's up here. Thanks! Ben Smith |
10-16-2013, 05:06 PM | #2 |
Re: differences in disc brake spindles between 1968 and 1972
here are a couple of pictures of the spindles I am using, the foil like material on the spindle pins is actually aluminum furnace tape, I used that to mask the machined areas of my spindles when I powder coated them with everything else. these aren't the best, but at least they are pictures......I'll post better ones tomorrow.
Ben |
10-17-2013, 01:14 PM | #3 |
well, I think that I have a drivers side spindle from a '68 C20 and the passenger side from a '71 C10........now to buy the correct Tie rod end.....
10-17-2013, 01:44 PM | #4 |
Moderator
A 68 C20 had drum brakes. You probably have a 73-up spindle. Take it to a parts store and verify by finding a tie rod end that fits.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
10-18-2013, 05:13 PM | #5 |
LedZepp,
Thanks for the info! this project is driving me crazy, but that's what I get for buying a "Basket Case" Thanks again! Ben Smith |
