10-16-2013, 08:23 PM | #1 |
removing rear leaf springs
Any idea's on how to safely remove rear leaf springs on a 1971 gmc 2wd swb truck and put them under the axle, I know i will need longer u bolts anything else? can I still use my old springs, and how much will it lower the truck
10-17-2013, 05:53 PM | #2 |
Re: removing rear leaf springs
I would look at a flip kit, because you will still need some sort of axle saddle or mounting bracket for the bottom side of the axle when mounting to the top of the spring.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
10-18-2013, 11:09 AM | #3 |
The axle flip kit appears to be the easiest route. I would unbolt the rear end and relocate it with the springs in place. With a few jack stands and a hydraulic jack, you shouldn't have any problems, as its a fairly straight forward project with a flip kit.
11-13-2013, 10:07 PM | #4 |
Here's my experience. LWB, but should be very similar. http://67-72chevytrucks.com/vboard/s...d.php?t=577529
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
11-14-2013, 12:00 AM | #5 |
I did the DJM rear flip kit. Pretty straight forward
71 swb 350/4sp manual 5/7 static drop |
