10-16-2013, 11:44 PM | #1 |
Static drop (front) & air ride (rear) suggestions
First post here. Hope this is the right place!
Haven't had a classic truck since high school (over a decade ago) but I have my sights set on a great condition '71 Custom Deluxe to be my daily driver. Yes, I'm getting rid of my modern SUV! My question is this: Since this will be my daily driver and I still want to be able to haul things (furniture, maybe a small atv trailer), what static drop in front and air ride in the rear set-up do you guys suggest? I've scoured the threads here and, for economical reasons, I think I'd like to do a ECE 2.5" spindle with their 1.5" coil up front and (possibly) their rear air ride suspension kit. I do not want to notch the frame and I want the best ride possible since it will be a DD. For reference, I'd like to run 20" wheels with likely 255/40 series tires all around. Any issues I should be concerned with regarding camber in the front due to the adjustability in the rear? Feel free to post up pics of your static front/ air ride rear rides. Thanks! |
10-17-2013, 01:36 AM | #2 |
Re: Static drop (front) & air ride (rear) suggestions
You're in luck with the 71 c10, you have several options for drop spindles. I purposely bought a long bed for all the reasons you described. I have some tossed quads, couches, refrigerator, and many more items in my bed. If you want to go budget, I'd do a simple bag, bracket setup, with a line and Schrader valve. Since you don't need to be lifting and lowering at every corner, you'd save a ton of money on parts since bags are like $120, brackets are about $60, and the line kit is only about $40.
I actually had a 72 with a 2" spindle, and a 2" coil. I was running 245/45-20 which is taller than what you're planning. I had a few issues with the steeper than average driveways. I was no longer able to go to the burger king by my house, but that's a good thing, my truck kept me on a no burger king diet.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
10-17-2013, 05:27 AM | #3 |
MSHAX please can you post some pics of your truck so we can see the setup you speak of. Thanks
------------------------------------------------------ ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560 |
10-17-2013, 09:17 AM | #4 | |
10-17-2013, 09:30 AM | #5 |
Thanks Scoti, how many coils cut in front?
10-17-2013, 10:08 AM | #6 |
1 coil cut. In my opinion, if anything more is required to achieve the desired stance, a different spring should be utilized.
10-17-2013, 10:10 AM | #7 |
Problem I have is drum brakes up front still, I am working on upgrading disk brakes so I can purchase spindles.
10-17-2013, 10:47 AM | #8 |
Discs & drop spindles is the way to go. That 68 in the pics had that disc swap done & front suspension rebuild (BJ's, tie-rods, etc...). I added fresh gas shocks plus a HD 1.25" sway bar w/poly bushings too. Night & day difference driving down the road.
10-17-2013, 10:09 PM | #9 |
Thanks for the responses! I may end up doing a 3.5x5 ECE kit. Wouldn't shortened bump stops help with bottoming out in the rear? Any suggestions there?
Also tire recommendations and back spacing? Not sure that I want to go with a larger tire in rear/steep rake look. |
10-18-2013, 02:24 AM | #10 |
I really want to go the discs and spindle route however because I am on the other side of the world shipping the items is working out a lot so I will have to wait on this. I first need to order my rocker panels and mirrors etc.
10-18-2013, 03:44 AM | #11 | |
It's like my life began in May of this year
10-18-2013, 03:59 AM | #12 |
MSHAX, buddy shame sorry to hear about the damages. Even though technology is taking over I still feel keeping photos is still the best unless of course that also gets water damaged ......Lesson learnt don't go to LA...... haha
When you all settled and house rebuilt please share some pictures. All the best with the rebuild.....
10-18-2013, 06:27 PM | #13 |
AGREED!!
It's all rebuilt now, only took them 4 months to put in all new floors, ceilings, walls, and a bunch of electrical.
11-09-2013, 06:42 PM | #14 |
I know this may sound stupid but what exactly is a static drop
11-09-2013, 08:58 PM | #15 |
Static means you cant change it like air ride, not sure if adjustable coilovers are considered static or not.
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo '81 C-10 SWB Parts Truck IRC - http://webchat.snoonet.org/#baggedtrucks |
11-09-2013, 09:07 PM | #16 |
Simply put, it's permanent. You change things like springs, spindles (where the brakes & wheel attaches to the front suspension), and put blocks in-between the rear axle and suspension. Air bags are used to change the ride height by adding & removing air pressure in the system. You can change your trucks stance (how it sits) in a few seconds...
Only 6 post, must be new around here! No dumb questions!! I'm pretty new here too!
8/24/13 First Classic Truck '67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny. |
