Old 10-17-2013, 07:21 AM   #1
hugger6933
When blowing apart your beds,
how are you men/women handling the bolts that are turning in the "pockets"? Or the square portions where the carriage head part of the bolt rides. I have one of my beds in the shop on the bed dolly and some of the front panel bolts just wouldn't come out even after brushing and spraying. I cut those off with the die grinder. The ones along the bedsides I had thought about tack welding the heads to the floor, then removing the weld with the die grinder after the side is off and the access is easier. So whatcadoin? Jim
hugger6933 is offline   Reply With Quote
Old 10-17-2013, 07:40 AM   #2
chiefcfd
chiefcfd's Avatar
Re: When blowing apart your beds,
This was the hardest part of my destruction process. Most came off. Some I used the die grinder. I cut a slot in the head and used a large flat screwdriver. Others I used vise grips to hold. Welder might be a good option, I didn't try that one. Sometimes you can tighten them and snap them off when they spin in the slot. Good luck. Sometimes I just walk away and try another day.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 10-17-2013, 07:58 AM   #3
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Tac welding sounds like a great idea. I used the grinder on my stubborn bolts. Like chief said, sometimes walking away and trying later helps also.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 10-17-2013, 08:39 AM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Tighten them until they break, or set a nut on top of the head and throw a weld on the inside where the threads are then you can put a wrench on it.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-17-2013, 08:48 AM   #5
Dano69c10
Dano69c10's Avatar
This is the method I use; I use my 4" cutting wheel and cut into the bolts as such.
If you have a real steady hand, then cut a little more;
The nut will either fall off the bolt, or you can wrench off the bolt easily.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 10-17-2013, 09:00 AM   #6
dfwright
dfwright's Avatar
I had to weld a nut onto the head of a couple of them to get them off. I cut the ones I could.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-17-2013, 10:06 AM   #7
Johnnyfever
I used a titanium drill bit to drill a hole in the head of the bolt and used an easy-out in the newly created hole in the bolt head. Then just a ratcheting wrench on the nut underneath. And I had to do this on every single bolt I had. Only took about 45 minutes after I picked up the titanium 3/16" bit....cut through like butter.
Yes, it's a Short Wheel Base, not a Short Wide Bed.
Johnnyfever is offline   Reply With Quote
Old 10-17-2013, 10:19 AM   #8
YBNORML
YBNORML's Avatar
I used to dick around by trying to unbolt everything. Now I just flip the bed over and grind them off to begin with. Bolts are cheap and it saves a ton of aggravation.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 10-17-2013, 11:38 AM   #9
hugger6933
I ended up welding nuts onto the carriage heads and holding with a wrench. I have another one to do real soon so YBNORMAL's course of action was my next thought with my exception of standing it up on the front panel to cut the m off with either the torch or plasma cutter. Jim
Old 10-17-2013, 02:02 PM   #10
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
The fastest way is to drill the heads off, Start with a small bit, center it and then use a bigger bit the same size of the bolt. It goes real quick if you have sharp bits.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 10-17-2013, 02:08 PM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
I cut an X into the head of the bolt with a cut off wheel. That usually removes enough material/weakens the head enough to tap a large screwdriver under it and pop it off.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-17-2013, 04:37 PM   #12
hugger6933
Well I got this bed done now on the next one next week, I'll do different but this one I ground the heads down on some and tapped the down with a hammer and punch and then on some other I welded nuts to them and held them with a wrench. Jim
Old 10-23-2013, 01:49 PM   #13
73737373
Cut a groove in the bolt so it looks like a screw head. Then use a screwdriver to hold the bolt head and get your buddy to turn the nut.
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 10-23-2013, 02:43 PM   #14
Maxxd07
Maxxd07's Avatar
If you have some scrap length of rod or flat stock you can weld it to the heads of several bolts at once and climb under and loosen the nuts as a one man show. I haven't done it yet but once I get going that is my plan.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 10-23-2013, 03:51 PM   #15
YBNORML
YBNORML's Avatar
Although all of these ideas wil accomplish the task, most of them run the risk of rounding out the holes on the boxside or nicking the sheetmetal with the grinder. That is why I prefer the flip and cut method. Any accidental marks are on the underside.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
