Old 10-17-2013, 10:45 AM   #1
63chevyfleet
63chevyfleet's Avatar
difference between 3 speed trannys
Hey y'all on the board my question..... ok I have a 63 c10 and my original tranmy went out because of the syncros in the tranny. Now my question will 55-57 car 3 speed trannys fit in 60-66 chevy trucks? Like clutch spline?
63chevyfleet is offline   Reply With Quote
Old 10-17-2013, 05:22 PM   #2
Wrenchbender Ret
Re: difference between 3 speed trannys
The bolt up to the bell housing & clutch is the same but you may run into problems with shift linkage & drive shaft length.
Wrenchbender Ret is offline   Reply With Quote
Old 10-17-2013, 05:41 PM   #3
63burban
Chevy addict
Physically the same but different ratios in first and second.
63burban is offline   Reply With Quote
Old 10-17-2013, 07:03 PM   #4
63chevyfleet
Oh OK...thanks for the replys.....can I measure the length of the trannys from the front to the tail end? And if it is the same I should be fine right?
Old 10-17-2013, 08:17 PM   #5
1963c-10
1963c-10's Avatar
hook onto the front of the main case and measure until the end of the tail shaft case. you should be aable to find a replacement 3 speed fairly easy though. if you were closer, id give you one.
as stated above, i think linkage will be your biggest issue to retain the column mount
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-18-2013, 12:47 PM   #6
61K10
61K10's Avatar
if for some reason the linkage to trans is different just use your old side plate off the old one.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
