6 lug disc brakes onto a 1967 C20
I have read through a lot of threads on the disc brake conversions but I have just one question. I have a 1967 C20 and want the 6 lug setup, I read that to do this on a 1/2 ton you use 1988 truck parts and a 3/4 ton lower a arm. I have the lower a arm on my truck already being a c20 so I need a 1/2 upper arm. What years can I use for the 1/2 ton a arm is it only 1967-72 or van I use them from a 73-87 or the 1988. Or can I just use my 3/4 ton upper arm. Can someone point me in the right direction, I don't want to buy an aftermarket kit.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 6 lug disc brakes onto a 1967 C20
You can use your C20 upper arm.
Just install the correct balljoint.
Which year truck would the upper ball joint be from the 88 or the stock 67
Balljoints have to match the year of spindle you are using.
