10-17-2013, 09:06 PM | #1 |
LT1 swap power steering lines
I am swapping in a 1995 LT1 and I am having trouble figuring out what power steering lines to use. I am using the stock LT1 pump that is located on the passenger side of the motor. Any help would be greatly appreciated.
Thanks in advance 1967 Short step |
10-17-2013, 10:22 PM | #2 |
Suppose to be workin........
Re: LT1 swap power steering lines
You more than likely will have custom ones made up. I believe that the lines on the LT1 are metric and the the truck is of course not. The other option is braided steel lines.
Brent '68 C10 '70 C10 '72 LeMans "03 Trailblazer "Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown |
10-17-2013, 11:52 PM | #3 |
I have a 95 LT1 that i bought to install in my 71. But i have ben second thinking that one. If you have any pics or can give me some points on the install I would appreciate it respectfully..
True |
10-18-2013, 12:16 AM | #4 |
You must have an lt1 out of an f body (?) on b body the pumps are on the ds. I am pretty sure the vette has it on ds as well, not sure. How about swapping accessory drives? If you dont want to run ps at all, i cam across this:
http://forums.hybridz.org/topic/6679...steering-pump/ |
10-18-2013, 08:10 AM | #5 |
Use the lines that come with each and mate them in the middle. Install the engine and take the original truck line and the LT1 line and lay them next to each other. In a nice obscure place, cut them both. Take them to a good auto parts store or place that makes hydraulic hoses. Have them install a male JIC in one and a female JIC fitting in the other. Mate the 2 together and cover with split loom if you like. Cheap, fast, easy.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
10-18-2013, 09:16 AM | #6 |
I believe you can unscrew the bit nut/fitting on the ps pump and that "cartridge" with spring comes out.you can do the same thing with your current older ps pump and replace the new one with the old one so they will both match your current hose. Now the location may still merit a new hose due to the length. If that is the case you can like said above just have a new hose with what ever ends you decide installed.
On my ls swap I did just that and am using my original hoses. Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-18-2013, 11:10 AM | #7 | |
10-18-2013, 11:14 AM | #8 |
Use a Camaro or Firebird radiator, fans and fuel lines. They are close to plug and play. I will be using an inline fuel pump so I don't have to relocate my tank. I am going to swing my motor and trans this coming week. If you have any other q's, drop me a line. Work in progress.
10-18-2013, 11:15 AM | #9 |
Great ideas. I like the "use both lines" idea. Thanks to all.
10-18-2013, 02:56 PM | #10 |
take both ends the truck end and the pump end and have a hose made with your old ends. A rad shop or any hyd shop can do this.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
10-21-2013, 12:36 PM | #11 |
What did you do for a gas pedal? I have a 67 and a 72 gas pedal and they are both to close to the fuel pressure regulator.
10-21-2013, 07:16 PM | #12 |
Street and performance in Mena Arkansas can make whatever you need. (hotrodlane.cc) I used one of their remote reservoirs; and used their diagram for power steering and had a local hydraulics shop make me the required lines. they have a wealth of information for LT-1s and LS type engines on their website.
Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
10-21-2013, 07:17 PM | #13 |
My fuel regulator on the LT-1 is on the right side. As I stated before Street and performance has what you need. As far as a gas pedal, I used stock. I used a Lokar linkage that works great.
Kerry
