Old 10-17-2013, 09:40 PM   #1
rich67
rich67's Avatar
posi/ no-spin
two different codes and i assume two different setups. can anyone explain? thanx rich
rich67 is offline   Reply With Quote
Old 10-17-2013, 10:00 PM   #2
Bigdav160
Bigdav160's Avatar
Re: posi/ no-spin
Their was actually three traction aid codes
G80 was a limited slip that used spring loaded multiple disc clutches attached to both axles. This type is rebuildable and allows some slippage between left and right tires.
G86 was a "lunch box" locker used in the heavy duty 3/4 ton and up Eaton axle. When locked there is no difference in speed between left and right axles.
G87 was a clutch style with a leveraged differential pin (power loc?) used in heavy duty Dana axles. The more torque applied the tighter this axle holds both axles together.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-18-2013, 09:40 AM   #3
Re: posi/ no-spin
K5-CK10 (12-bolt) got the G80,the typical Positrac. CK20/2500-30/3500 (with HO52/72) got the G86,the No-Spin (Detroit Locker). CK20/2500-30/3500 (with Dana60) got the G87,the Power-Loc or Max Traction. A 6-lug Dana 44 or 60 rear could be had in a C1500,which could have the G87.
