Old 10-17-2013, 10:36 PM   #1
possum1
A/C swap
I have read on some builds about mounting the in cab box from a mid 90's Chevrolet truck in our cabs. I have started the process and would love some tips. If not, I guess I will be starting a swap thread.
possum1 is offline   Reply With Quote
Old 10-18-2013, 12:07 AM   #2
ole dollor
ole dollor's Avatar
Re: A/C swap
I have not seen this done, I also would like to see it done, I will hang around and see how it turns out...good luck on the AC swap. do you have an ac cab now, or a non ac cab?
ole dollor is offline   Reply With Quote
Old 10-18-2013, 09:23 AM   #3
possum1
Re: A/C swap
It is not a ac cab now, but I have changed one over before with original components. I have the box the majority of the way in now, but will have to change the box some and the upper right cowl. I have a old cab and think I will cut it up to make it fit there first. then transfer over to the cab I'm using.
Old 10-19-2013, 12:51 AM   #4
possum1
Re: A/C swap
Looks like fairly major metal work if I keep the fresh air intake. What's the opinion on doing cab/recirculate air only?
Old 10-19-2013, 07:19 AM   #5
Bigdav160
Bigdav160's Avatar
Re: A/C swap
It'll be fine. The aftermarket kits do not use fresh air and in fact, I think, if you install aftermarket A/C in a A/C cab they tell you to not use the fresh air return.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
