Junior Member
help question"oem stock'
need help on my 1972 blazer 350 a/c auto 4x4 1) what battery did gm put in my truck. top or side post. 2) where did the ground cable mount on the motor 3) on the bottom of the fan shroud does it mount with speed clips and screws or snap in clips 4) on the pos battery cable how many holders are there. thanks for all your help mark fine 67
#2 | |
Re: help question"oem stock'
Not sure about the ground.. I've had my motor out.. But have never changed cables, and it's so short I grounded to my a/c bracket. It's about as far as it will reach The shroud bottom just pushes down into some clips at the bottom The pos cable has one lead that goes to a little plastic juntion box on the inner fender right by the battery. |
