Old 10-18-2013, 02:09 PM   #1
mvitale27
mvitale27's Avatar
56 3600 SBC/4WD Trans Question
Hey guys,
I have a 383 stroker I built from a 73 vette's 350. I am going to do a 4WD conversion on my truck and I already have an np205 transfer case. I will most likely be running Dana 44 in the front and corporate 12 in the rear. 383 will be putting out about 400 hp and 450 ft lbs of torque.
I am looking for a 5-speed manual w/ overdrive. I heard good things about the NV4500 and I know it hooks up with the SBC and np205, but I also believe it is a low-geared slow-shifting truck tranny? Mainly this truck is going to be powerful, the 4WD conversion is only for snowy winters. I need the overdrive for 3 hours of daily highway/country road commuting and I would like a sportier transmission. I was looking for more of something like the Tremec TKO, but I don't believe it will work with the np205.
Any ideas?
1956 Chevy 3600
Matt's 3/4T 4X4 Build
mvitale27 is offline   Reply With Quote
Old 10-18-2013, 03:01 PM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: 56 3600 SBC/4WD Trans Question
I would go with a divorced NP205 from an early to mid 70s Dodge, that way you can run any Trans you can come up with and not have to worry about adapting a Trans to work.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-19-2013, 03:21 AM   #3
andrewmp6
I would do the nv4500 with the adapter kit to use the np205 on it.But what size tires are you going to run on it?
andrewmp6 is offline   Reply With Quote
Old 10-19-2013, 12:18 PM   #4
argonaut
argonaut's Avatar
If you decide on an nv4500 use a 95+ version. 1st gear isn't as low and the gears are spaced more closely together.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-20-2013, 10:26 PM   #5
mvitale27
mvitale27's Avatar
Thanks for the info if I do decide to go with the nv4500
1956 Chevy 3600
Old 10-22-2013, 09:15 AM   #6
mvitale27
mvitale27's Avatar
I am pretty sure I will be going with 3.73 gears and about 29" tires. After doing some more research, I am leaning back towards the nv4500/np205 again. This thing is going to be heavy and possible tow the snowmobiles back and forth from Rhode Island to Maine.
1956 Chevy 3600
