Truck wont turn on!!!
Today i was going to pull out my truck out of the garage and when i put the keys in it didn't turn on. i thought it was the battery but i checked it and its fine. what can it be?
![]() Join Date: Dec 2012
Re: Truck wont turn on!!!
check fuze link at battery
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
sorry fuze link at starter
if the starter dont work do the lights still turn on or no?
Check the connections to your starter, I've had this happen multiple times due to my starter silinoid going out. Also check your battery cables, make sure your negative is grounded to a CLEAN bare metal spot on the block. Then also like stated above there is a fuse link on the ignition wire that will burn out. Last but not least check that your wires have not burnt through buy laying on headers or engine block! If you come up with all this stuff ok we can go from hear. It's like running medical tests, rule out the easy stuff first! Let us know how it goes!
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
Does it click several times when you turn the key??? LIghts dim or not working??? If so, dead/dying battery.
Yes, lights will work just fine if the starter is bad. Radio will work, power windows/etc will all still work if it's the starter. If there's no clicking when trying to start it, and all other accessories work, then you either have a bad power lead from battery, bad lead to the solenoid, bad ignition switch box, or bad starter itself. Rare, but on occasion, you can get a bad cell in a battery that only shuts off when under high load. Those can be tough to diagnose.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
| Bookmarks |
