![]() Join Date: Nov 2007
Few Carb engine parts
All parts located in 72120. Can pick method of shipping, ups, usps, fedex.
1. Edelbrock 2101 intake. Used for about 1 year and likely less then 1000 miles. I am keeping the t-stat neck. Asking 100 plus shipping. sold 2. HEI Billet distributor. This is part of the LMC kit. I have broken the tabs on the wireharness, but it still stays plugged in. Asking 50 plus shipping. 3. Holley 6772 carb. This is old school, was part of the 4160 series. 650cfm double pumper. My first attempt at rebuilding carbs. It has 56 jets up front, 61 jets rear, front and rear power valves. Comes with carb spacer. Asking 40 plus shipping.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) Last edited by Dale99; 11-12-2013 at 10:42 AM. |
One of the First
![]() Join Date: Jan 2000
Re: Few Carb engine parts
Can you do $110.00 shipped for the intake?
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
It says 27 for shipping to you via USPS. Id do 115 to your door.
Any play in the throttle shafts of the carb? Looks like all is there? Could not tell in picture but is choke actuation linkage all intact? Was it working properly when it was removed? Thanks much, Bob
Bob, were not finding any side to side play in the shafts. Needs an air cleaner stud. After the rebuild we got the carb to adjust and drove on it. Engine started acting weird and we went to adjust the carb and it wouldn't. I was told that was an engine problem, not a carb problem. Attached is picture of choke side of it. Far as I know everything but the heli-coil spring for the heat sensitive choke is here... its still on the intake. Which I guess since it hasn't sold officially yet, I can send it with the carb.
One of the First
Sounds good...
TTT with new prices.
Whats the new price on the carb? I might be willing to take a chance on it if it can be shipped reasonably?
Thanks again, Bob |
40, it was 50.
U cud make a manual choke out of it cudnt u?
rich, I have no clue. This is my first experience with carbs, and wish I would have tossed it far as I could, rather then attempting to make it work.
| Bookmarks |
