Old 10-18-2013, 08:32 PM   #1
REEDS 72
REEDS 72's Avatar
Big block starter brace
Hi, I am trying to find out if a big block starter motor brace was used in 1972 and if so, does anyone know how they were attached and the part numbers? Any response is appreciated.
REEDS 72 is offline   Reply With Quote
Old 10-19-2013, 04:31 AM   #2
John Pasinski
John Pasinski's Avatar
Re: Big block starter brace
I have a '72 C30 w/ a 402 BB. All OE, and it never had a starter brace.
I'm guessing it's because the starter is bolted through the bell housing as well as to the block?
I haven't come across it in the Factory Assembly Manual either.
Keep checking your post, maybe someone else has a better answer.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 10-19-2013, 08:33 AM   #3
Rascal_one2001
Rascal_one2001's Avatar
I just had a 70 in the shop that had a 396 out of a chevelle in it with an automatic trans we put a regular little starter bracket on it the block is tapped for a 5/16 and you can get the bracket for $7. It may not be factory for your truck but it should bolt up as long as you have a stud on your starter
Part Number 03965588
The bracket also lines up on my early model 454
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
