Old 10-18-2013, 09:27 PM   #1
69SCSS
69SCSS's Avatar
200-4R behind a BBC
Just wondering what everyone's opinion is. I have a choice of 2 200-R4's in the area less than $500 each, rebuilt, with TV cable and one has the lockup wiring kit. I'm wondering about if this will live behind a 402. I'm sure if I never open up the secondaries on the carb it'll last forever, or never tow with it, but we all know there's no way I'm keeping my foot out of it! From what i've read they don't have as much torque capacity as a 700R-4 or even the TH400 I currently have. A couple advantages though are the fact it bolts right in place of my TH400 and would even use the same converter as the 700R4 if I decide to swap it out. What do you guys think? Are there multiple versions of the 200-4R like the 700R4 for different engines (one of these is from a 4.3 V6 but he doesn't know what it was originally from). If I had a SBC I wouldn't even worry about this, but I didn't put a BBC into my truck to drive it like a 250.
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 10-18-2013, 09:45 PM   #2
Mike C
Mike C's Avatar
Re: 200-4R behind a BBC
I think the 200 4R is a great choice for trans. The $500 may not live that long behind your 402, but it can be built to take 2000 hp Buick Grand National motors. The gear ratio makes so much more sense than the ridiculous 1-2 break on the 700.
You do have to change the yoke on your 400 at minimum since the 200 isn't the 40 spline output but a 32.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-18-2013, 09:52 PM   #3
Keith Seymore
Keith Seymore's Avatar
Agree.
I've got a '67 Buick TH400 in my '63 GP; I'd like to go to a 200-4R to make it a bit more freeway friendly. I've heard a lot of good things about them.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-18-2013, 11:04 PM   #4
bbcmudtruck
Have you looked into a gear vendors over drive unit? It will install behind your current 400 and will easily handle your power out put. Plus if you decide to go bigger in the future, its rated at 1500 hp. They are pricey, but I have yet to see a supposedly built 700r4 live very long behind a high torque motor. In fact, most of the big name tranny shops wont even build them.
bbcmudtruck is offline   Reply With Quote
Old 10-18-2013, 11:22 PM   #5
69SCSS
69SCSS's Avatar
Thought of that and almost bought one off the board here a few months ago, but didn't have the funds at the time so I had to pass. I keep an eye on the board and on Ebay but they're still not too common for reasonable. I found one that started at $400 2 days ago, and it immediately disappeared. I keep fishing for ideas, trying to keep the truck as simple as possible, and the GV unit would make that easy... just gotta find one for less than that $3k asking price new.
My 68 SWB
Al Silveira Music
Old 10-19-2013, 04:45 AM   #6
JointTech
JointTech's Avatar
I figure 3k is 7500 miles worth of gas. Youll gain maybe 5mpg with a GV?
Seems like it would take a long time to earn that money back on my grocery getter. In fact I doubt this truck sees another 7500 miles in its lifetime. Would be nice not hearing it scream on the highway though. But then again a new stereo or some ear plugs would take care of that as well.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 10-19-2013, 07:00 AM   #7
jjzepplin
jjzepplin's Avatar
I don't look at OD's as saving gas but saving your motor. Less rpms mean more longevity. For what it's worth I've had my 1989 700r4 behind my built 406 for over ten years. I built it myself with B-M kit. 9 clutches where there used to be 6 etc. Just stay away from TCI converters. My .02c.
Oh yeah- it cost $50 at the junk yard...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-19-2013, 07:15 AM   #8
Bigdav160
Bigdav160's Avatar
Have you ever looked inside a 200-4R? It's full of sheet metal parts. Without heavy modifications, I'd say, maybe a week before it blew up.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-19-2013, 07:32 AM   #9
hugger6933
I think maybe more study is in order for this swap. First it is the same length and yoke as the th350, not the th400. Next, I'm not real sure about the interchange of the converters either. As for the reilibility they [the General ] put those trannys in behind the Montoe Carlo SS and the Buick Regal T Type with the turbo and those two cars were fairly fast back in the day so if you have to have a 2004R try to get the "good" one like came out of one of those cars.
hugger6933 is offline   Reply With Quote
Old 10-19-2013, 07:56 AM   #10
Mike C
Mike C's Avatar
Crossmember mount is same position as TH400 but as noted, the length and driveshaft are same as TH350.
Like I said above, the Grand National's 3.8 SFI turbo motor came with a TH200-4R and with a chip it easily put out 350 rwhp and probably 450 lb/ft torque. It should hold up to a mild big block if the trans is built using the internals from one of those. Obviously the TH200 that came behiind a 3.8 non-turbo would not be as beefed up.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-19-2013, 08:13 AM   #11
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Save your money up and look/ and wait for a used GV unit. You will be the happiest guy on the block, and you Cant break it.
Tom Vogel is offline   Reply With Quote
Old 10-19-2013, 08:27 AM   #12
Rascal_one2001
Rascal_one2001's Avatar
I run a trans shop I would never run a bolt on over drive since they break a tiny internal spray and you loose reverse then have to have the entire unit rebuilt. If you have a bop engine yes the 200 r4 is your best bet but since you have a Chevy engine go with the 700 but you will have to have it headed up to handle the torque same with the 200. If you break down both transmissions and look at the hard parts and planetary gears you would run 700r over the 200. You can put raybestos stage 1 clutches, beast sun shell, 5 pinion planets, corvette servo and z pack 3-4 clutches and a 700 is good for 500hp
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 10-19-2013, 08:32 AM   #13
bbcmudtruck
FYI, there is a used GV on the Kansas city craigslist!
Old 10-19-2013, 10:49 AM   #14
motorcritter
motorcritter's Avatar
I agree with Rascal. I used to run a trans shop, and we built 700R4's that put up with serious abuse. It'll be cheaper than a GV unit, and finding and building an adequate 200 can be problematic, in comparison. I'm a big fan of manual trans units, but if were going to use a gen1 sbc or bbc, I would go with a 700 or 4L60- built right, of course. With a modern (LSx) engine, one of the newer GM auto units would be a logical decision.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
