Old 10-18-2013, 10:53 PM   #1
az's1971C10
az's1971C10's Avatar
700R4, which donor car & what gears
Hey guys,
If you could pick a donor vehicle for a 700R4 swap what vehicle would you choose and what gear ratio??
I have a 71 SWB with a 350 mated to a Saginaw 4 speed with 3.08 gears. I plan to do a swap next spring/summer after my daughter learns to drive the 4 speed. It's going to be her truck when she turns 16.
Thanks for your help.
az's1971C10 is offline   Reply With Quote
Old 10-19-2013, 12:20 AM   #2
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: 700R4, which donor car & what gears
87 to 92 are best & I tried, despite all the warnings here, to run a 3.08 rear gear. It it ended up being too tall a rear gear with my 29" tires & I ended up having to change it to a 3.73.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-19-2013, 01:59 AM   #3
leftybass209
leftybass209's Avatar
88 and up had some GM improvements. If you are getting a rebuild the year won't matter. 3.73s are great. 3.30s and 3.90s will also work but I have heard complaints of 3.30s borderline too tall.
leftybass209 is offline   Reply With Quote
Old 10-19-2013, 07:41 AM   #4
hugger6933
88-93 C trucks and the Roadmasters and Caprice with the tbi engine[by the time they went to the LT1 it was a 4l60E and You don't want to open that can of worm about he electric stuff for the shifting. As far as the gears go one of my favs that has not been brought up is the best of both worlds [or so it has been called that at times by several people] is the 3:42 gear. It is still low enough to get the heavy truck moving yet high enough to let the truck throttle back some on the open road. Good luck and I hope you and your daughter enjoy your time together and the truck. Jim
hugger6933 is offline   Reply With Quote
Old 10-19-2013, 07:53 AM   #5
az's1971C10
Thanks for the info gentleman.
Old 10-19-2013, 08:16 AM   #6
Rascal_one2001
Rascal_one2001's Avatar
The 87 -93 700r4 is the best since it runs an auxiliary valve body and has better designed valve body. If you get one with electronic speedo you can just cut off the metal reluctor wheel and the holes to mount cable drive gears are under it. 3.73 gears will still let you cruise at 65.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 10-19-2013, 11:42 AM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Ive been checking this out for years and I agree if you want the best of both worlds, city and highway driving and an occasional stoplight blast a 700R4 with 3:42's and a 27 to 29 inch overall tire height should do it for you.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-19-2013, 01:58 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I have to agree with the 3:42 gear,though the 3:73 is great also.The 3:42 was the go to gear ratio for GM with this tranny so I'm sure the engineers were close.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-19-2013, 02:13 PM   #9
Tachout
I have seen several different sugestions of trans and what it comes out of. Just wondering why no one has sugested the 700R4 out of the Corvette. I have a Pair of 90 Corvettes that both came with the 700R4. Is there something wrong with that trans?
Tachout is offline   Reply With Quote
Old 10-19-2013, 03:48 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
Great donor but few and far between. I believe they also only had an electronic speedo. Any 700r4 can be upgrded to vette specs at time of rebuild.
WIDESIDE72 is offline   Reply With Quote
Old 10-19-2013, 04:44 PM   #11
Tachout
The electronic speedo is easy to work around. If any of you are working with C4 corvette parts or want to source parts let me know. The National Corvette Forum is a great place to source parts.
Old 10-19-2013, 08:59 PM   #12
az's1971C10
Thanks for the great info from everyone. I now know what to look for.
Cheers
Old 10-19-2013, 10:03 PM   #13
slow-1
slow-1's Avatar
Just to throw a curve at you...I am running 3.08 gears with my 700r4 and am happy with them. But I've never had other gears in the truck so nothing to compare it to.
You could always try it first...unless you are having to change the gears anyway.
Don't know how tall my tires are, maybe that's the difference...they are 255/70/15's.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 10-19-2013, 10:15 PM   #14
Already Gone
Your tires are 29.4 inches high. Some board members have said they were/are not happy with 3:08's and 700r4's cause you dont rev very high at highway speeds and even when you climb a slight grade you drop a gear sometimes 2. My 99 Tahoe 4 x 2 with a 350, 4l60 and 3:08's is a great combo for power and gas mileage.
Old 10-19-2013, 11:47 PM   #15
powell72
powell72's Avatar
I ran 3.73's behind my 700R4 for years with a 28" tall tire. If I did it over I'd run 3.42's.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
