spare tire
Any body got a good picure or diagram of a factory spare tire carrier?
#2 | |
Re: spare tire
Incidentally, here's the spare that had been riding around under there for who knows how long. (it wasn't nearly that clean when I pulled it out though.)
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack Last edited by Pick; 10-19-2013 at 08:11 AM. Reason: Added a comment. |
Re: spare tire
Thanks,nice find!
Re: spare tire
I'm sorry it is pretty bent up....but at least it will give you an idea how it was laid out.
It hung from the (bent) T-bolt and ran from the large hole in the far right rear to a long bolt in the smaller hole just behind the track bar mount on the left rear. I hope that helps.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
![]() Join Date: Nov 2012
Re: spare tire
Those things are so awkward to use! I HATE the ones on my trucks!
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
Re: spare tire
I agree. I'm not a big fan of the stock carrier. You could whip up something like I did on the cheap. I've got $20.00 something bucks invested in this. The winch came of a Mitsubishi truck. Some scrap metal, little welding, some bolts & nuts, and no more cussing the stock set-up! I set it up so the the crank rod is on the passenger side of the truck.
