Old 10-19-2013, 07:45 AM   #1
kenn
Diff fit Question
Hello, I have a 94 roadmaster for parts and was woundering if the posi will fit in my 72 c 10
kenn is offline   Reply With Quote
Old 10-19-2013, 08:00 AM   #2
hugger6933
Re: Diff fit Question
kenn, I'm gonna say no. The roadmaster has a 8.5 inch ring gear with 10 bolts attaching it to the carrier. The rear end in your truck is most likely a 12 bolt. Jim
hugger6933 is offline   Reply With Quote
Old 10-19-2013, 08:01 AM   #3
Mike C
Mike C's Avatar
Short answer: No.
Longer answer: Your C-10 has a 12 bolt cover truck-specific rear axle while the Roadmaster uses the GM corporate 10 bolt. The 10 bolt was also found in the back of trucks starting around 1980 in 2 wheel drive. They are 28 spline axle shafts until '88 when the new body style trucks received a 30 spline upgrade. The Roadmaster should be a 30 spline as well so would work in one of those.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-19-2013, 08:11 AM   #4
kenn
Thank you. The frame on my roadmaster broke and I was hopeing that I could swap parts.
Old 10-19-2013, 02:15 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If the complete rear end is the same width backing plate to backing plate,you could weld on new mounts and possibly use it if you can find a U-joint set to match up,but the 12 bolt is a stronger rear.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-19-2013, 05:11 PM   #6
kenn
Thanks. I need to put a posi in it and was looking to use what I had if I could.
Old 10-19-2013, 06:03 PM   #7
haminator
haminator's Avatar
That 10 bolt posi is worth 100 150 on Ebay,then you could use that money to buy one for the 12 bolt
haminator is offline   Reply With Quote
Old 10-22-2013, 09:55 AM   #8
kenn
I will get my daughter to do that, thanks. When I am ready to buy one i'll check back, this site seams to have a lot of info.
