Old 10-19-2013, 01:20 PM   #1
Pick
Pick's Avatar
Better? A-Arm bushings for a '68....
Is it just me, or are there simply no upgrade options out there? I figure I just must be overlooking the obvious, but I'm stumped.
I found a set of Competition Engineering upper A-Arm bushings, and nothing for the lowers, but that seems to be the extent of it. They apparently also fit '67-69 Camaros, some Chevelles, etc., so in theory I could use one of those options to try to work backwards. Maybe? But I thought I'd ask here to see if there is a simple (and hopefully cheap) solution that I'm missing.
What is everyone else using for bushings with stock '67-'70 a-arms?
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 10-19-2013, 08:42 PM   #2
mmiddle
mmiddle's Avatar
Re: Better? A-Arm bushings for a '68....
From 1970 down the A--arms had steel bushings. that worked a screw. There is no other replacement for them. The advantage is that there is no flex in these bushings. The disadvantage is ride quality. If you want urethane bushings you will have to upgrade to 71 up A-arms.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 10-19-2013, 08:52 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
72 and down used steel bushings. 73 and up used rubber. As a fact of trivia, heavy duty trucks used steel bushings much, much later. My 88 model dually has steel bushings.
To the original poster, what are you trying to accomplish with an upgrade ? You're not gonna improve performance. They're steel. No deflection or deforming under load. They're more stable than any urethane, prothane, delrin, or anything.
Old 10-19-2013, 09:05 PM   #4
mmiddle
mmiddle's Avatar
Yep... sorry, I forgot that they still had steel bushings. Yes I was aware on the heavy trucks having them in later years.
Mark
Jesus is the Way!
Old 10-19-2013, 09:07 PM   #5
Pick
Pick's Avatar
I hadn't gotten far enough into the cleaning and disassembly to realize they were steel and not rubber. I just assumed they were rubber and that prothane or delrin would be more rigid......but obviously not.
Thanks!
Unfortunately this probably won't be my last dumb question....
Old 10-19-2013, 10:45 PM   #6
heyjoe
You have now officially joined the "won't be my last dumb question" club.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
heyjoe is offline   Reply With Quote
