![]() Join Date: Aug 2011
Step Bumpers & Receiver Hitch
Does anyone have a Class III or IV receiver hitch installed on their truck with this type step bumpers?
I'm wanting to install a Class IV hitch but to me the bumper looks to low and to deep to use a receiver type hitch. |
Re: Step Bumpers & Receiver Hitch
Was wondering this myself. I'm not willing to switch to a sport style bumper for this option as I like the step bumper. Might have to go custom made.. I've got plenty of ride height, but consider on yours the ride height might be a little low. Nice truck by the way
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
![]() Join Date: Aug 2008
Not exactly the same situation but applicable situation: i had a 93 k2500 with a bent up stock bumper. I found a "ranch hand" pipe rear bumper on the local c list for $50(!). It came with no recieiver hitch provision. I already had a class 4 receiver hitch on the truck. I would not have been able to use it with the ranch hand because it hung too low and far out. I welded up an extension that went into the receiver and bolted to two of the three ball mount holes in the bumper using grade 8 1/2" bolts nuts and lock washers. One end was 2" od other end was 2" id. It was therefore bolted to the frame and bumper.
#4 | |
![]() ![]() Join Date: Sep 2008
Subscribed.
I'm still up in the air whether to go sport bumper or leave the step. BTW, Razorbacker, is that a Longhorn? |
#6 | |
![]() Join Date: Apr 2013
MY thought is loose the step bumper, but that's just me.
Now you might can install a class IV hitch and it will most likely interfere with the so called step/hitch plate some. So you might could notch out the area where the receiver plug will pass through the lower part of the step bumper. And depending on how they work together you might could fabricate some brackets between the hitch and the bumper. Depending on what kind of trailer and tounge weight your anticipating Shop around there are many different styles and configurations of receiver hitches out there depending on manufacturer.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
Interesting, We bought our 71 GMC BB Longhorn just north of Rogers.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
Allchevy, could you post a photo showing how and where that receiver connects to the bumper and frame.
I've been wondering this issue as I try to make my GMC with a nice step bumper work as a dedicated towing rig. |
I by no means have any factual data or measurements, but couldn't you use some type of hidden receiver hitch with a flip down license plate? That's what i did on my 3/4 suburban, although I have a sport bumper.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#13 |
I had a 70 GMC big block truck with a bumper like that I put a class IV receiver on with no problems. My current 69 short step has a class III on it with the step bumper and it too fits perfectly.
#14 |
#15 |
#16 |
#17 |
If you mount the receiver below the step bumper do you lose your spare tire mount? I'd like to see where the receiver mounts below your step bumper. A photo?
#18 | |||
Thanks, Tony |
#19 |
A class IV no drill receiver from Weaver Distributers
#20 |
If you want to retain the step bumper and this one hangs too low for the hitch you choose, I think some 1/2 ton step bumpers dropped down less.
#21 |
#22 | |
