10-19-2013, 10:36 PM | #1 |
spark plugs
changing from points to stock hei would like to use ac r46ts as i have a ton of them any thoughts
10-19-2013, 11:58 PM | #2 |
Re: spark plugs
Yeah, I sure would like a bowl of ice cream,oh, you mean about the oh ok oh oh. Now I am with you. I don't see any reason why not. Has someone told you that you could not run that plug in there? The only difference between the two would be the gap as far as I would think. I would open the gap up for sure on them before installing the HEI. I just don't see any other thing keeping it from working like you need it to. Jim [Oh yea, sorry 0.45 gap]
10-20-2013, 11:09 AM | #3 |
Re: spark plugs
The R46ts is a hot plug but should work good unless you are using it for severe service.
Like Hugger says increase the gap to .045. |
10-24-2013, 11:42 PM | #4 |
Re: spark plugs
thank you guys for your thoughts everything looks good except the new coil is bad no juice try again this weekend
10-26-2013, 12:03 PM | #5 |
Re: spark plugs
Check your ground tab on the coil. Easy to not hook up, no spark, no happiness!
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
