Old 10-19-2013, 10:45 PM   #1
Leverhead
Dash trim?
Hello. I've got these holes in my '64 C10 dash that look like they may have been there to fasten a piece of dash molding or something. I dont think they were installed by a PO as the holes are too perfect and perfectly spaced. Cant find the molding either. Does anyone know if this was a dealer installed option or something. Cant find 1 truck that has this. I also have these stainless moldings around the door glass which also is a mystery to me. Getting ready to re-paint the dash and not sure if I should fill the holes or not. Pics attached. Thanks.
Leverhead is offline   Reply With Quote
Old 10-19-2013, 11:00 PM   #2
1963c-10
1963c-10's Avatar
Re: Dash trim?
probably had a dashmat at some point. the stainless door trim around the glass was a gmc option. it was available on the 60-63 models also
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-19-2013, 11:01 PM   #3
NEWFISHER
NEWFISHER's Avatar
Re: Dash trim?
Mabey a padded dash? I say fill the holes in the dash and the doors then send me the trim
NEWFISHER is offline   Reply With Quote
Old 10-20-2013, 01:19 AM   #4
Captainfab
60-66 Nut
Re: Dash trim?
The holes in the dash are not factory. I have never seen any factory dash trim, or padding. I would just weld them shut.
That trim around the window on the door is commonly found on the GMC's.
Old 10-20-2013, 10:47 AM   #5
Leverhead
Re: Dash trim?
Thanks for the replies. Someone did a good job of drilling...was hoping it would be some kind of stainless molding or something. In the absence of the correct part I'll weld them shut. Regards.
