Old 10-19-2013, 11:46 PM   #1
Hart_Rod
Hart_Rod's Avatar
Question Thermostat .....
What temp thermostat are guys running? I've got the factory one in my LS3 but am wondering if I should go cooler because of the TVS 1900 supercharger?
Hart_Rod is offline   Reply With Quote
Old 10-19-2013, 11:55 PM   #2
jorgensensc
jorgensensc's Avatar
Re: Thermostat .....
Mine is factory. Of course mine doesn't have a supercharger! But my tuner (the good one that knows what he is talking about) said the fans cool it down quick enough that just adjusting the fan on temp was good. Just my .02.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-20-2013, 01:41 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Stock stat should be fine, but I understand going down to the 180* stat if you have enough other stuff putting out heat. I.e., a built tranny w/cooler, or in your case, the tvs1900.
If your putting out a good amount of heat load from the blower, the 180* will just help you run down the heat load a little quicker, and keep you from a panic attack in traffic. As always, it won't help much if your cooling system itself isn't up to the demand you put on it.
Don't go down to the 160*'s or anything like that. These motors are designed for 195-215*ish. Going lower will just make it run cold and rich.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
