Old 10-20-2013, 01:07 PM   #1
Psycho71
Psycho71's Avatar
'99 Burb a/c diverter
Just acquired a '99 burb (1500) SLE, having a small issue with the air diverter on the A/C. it will divert to the floor or defrost, but has a problem with diverting to the dash. Every now and then it will, but not often.
IIRC, these use a vacuum operated diverter. The engine has 160k miles, and and is in decent shape (so it seems). I'm thinking it should be making enough vacuum to activate the valve.
What say ye? Is this most likely a vacuum issue, or a diverter valve issue? Any advice before I find the lever and zip tie it into place?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 10-20-2013, 08:18 PM   #2
Boog
laying low
Boog's Avatar
Re: '99 Burb a/c diverter
The door actuators are electric these days, not vacumn. Here's a look behind the dash.
Boog
Old 10-20-2013, 08:57 PM   #3
Psycho71
Psycho71's Avatar
Electric, OK. Does anyone know which is more prone to failure, the switch or the actuator?
Thanks for the pic, I was looking for it today, and it wasn't in the same place the one on my '98 pickup was.
