Old 10-20-2013, 03:43 PM   #1
77chevyinline6
77chevyinline6's Avatar
Question T56 Trans swap?
Im tired of ripping out 3 speeds that i put behind my 350, and figured if im going to get something else might as well go all out right? what all would i need to do this? what will be different? what will be the same?
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 10-20-2013, 06:28 PM   #2
Unca
Re: T56 Trans swap?
Id ask how your tearing them up? Then an informed decision could be made.
Unca is offline   Reply With Quote
Old 10-21-2013, 04:55 AM   #3
superwade57
Re: T56 Trans swap?
Basics...
1. Lt1 t56
2. Adapter flywheel
3. Hydraulic clutch
4. Maybe a different driveshaft
5. Either bucket seats or a shifter relocation kit for the t56
That being said is it just that easy? No but is it hard? No depending on what you pay for the tranny you'll probably be in it 2000-2500$ 1200-1700 for tranny 200+ clutch 450 for flywheel $ for hydraulic pedal set plus master n slave and adapters. Youll have to use a speedo adapter. Thats another 300. Off the top of my head... I did mine on a budget. And I'm still In it about 1500 with a couple big breaks being $50 buckets and a $600 t56 and reusing the clutch and pp that came with it
superwade57 is offline   Reply With Quote
Old 10-21-2013, 07:54 AM   #4
superwade57
Re: T56 Trans swap?
Btw I'm using my garmin for a speedometer.
Old 10-21-2013, 03:07 PM   #5
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: T56 Trans swap?
You can also use an LS1 t56. There's a $200 adapter plate and $25 pilot bearing available that allows you to bolt the LS style trans to the original SBC bell housing and retain the SBC flywheel/clutch/linkage. I'm just about to do this swap, and relocate the shifter to the forward location to clear my bench seat.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
