Old 10-20-2013, 05:45 PM   #1
sixtwo
Help identifying what part to replace..
The back bushing on driver and passengers A-Arm has a lot of slop. But I can't seem to find the a-arm bushings for sale. Maybe I am missing something, all I can find is the center shaft.
Can someone point me in the right direction?
70 c10 2wd
sixtwo is offline   Reply With Quote
Old 10-20-2013, 06:18 PM   #2
Lee H
Lee H's Avatar
Re: Help identifying what part to replace..
If yours are worn out, that is the correct part. Do you have a shop manual, it contains step by step procedures for replacing these.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-20-2013, 06:20 PM   #3
Longhorn 70
Longhorn 70's Avatar
The shaft kit does come with bushings look HERE. This should be the right one if nothing has been altered.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 10-20-2013, 06:25 PM   #4
chiefcfd
chiefcfd's Avatar
There is no bushing in that area. The shaft nut is actually the bushing and fits inside the upper a-arm. Here is a pic hope this helps.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=142
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 10-20-2013, 07:36 PM   #5
sixtwo
Haven't picked up the shop manual for this vehicle yet. Definitely need to do that. So the shaft is the correct part to purchase then. Thanks a lot for the quick help!
This will be my first time doing front suspension. My father always did it for me years ago so this should be a good learning experience.
