Old 10-20-2013, 10:45 PM   #1
hunter_507
hunter_507's Avatar
Home built/custom rocker boxes
I was wondering how many people have made there own rocker boxes. I was thinking of doing this since the boxes are so expensive when you add in shipping. This is the only picture i could find of one done
1970 gmc Jimmy custom
hunter_507 is offline   Reply With Quote
Old 10-28-2013, 10:44 PM   #2
IwantaK5
Re: Home built/custom rocker boxes
I wish i would have done this. This seems like the way to go. Not only are you saving money but the floor will be stronger.
IwantaK5 is offline   Reply With Quote
Old 10-29-2013, 08:24 AM   #3
Chulisohombre
Chulisohombre's Avatar
There are a lot Of Guys that 4x there trucks that gut out the rocker boxes and rockers and replace them with 2x4 rock sliders that connect to the frame and replace the rockers and boxes. You could do The same and keep The rockers and just do like the guy above and weld in the seam to the edge of the 2x4 slider. Look up rock sliders and see what comes up. Should give you a few more ideas to Look at.
Chulisohombre is offline   Reply With Quote
Old 11-11-2013, 06:46 AM   #4
vtblazer
vtblazer's Avatar
The issue isn't the floor, it's the firewall moving around without the support of the rocker boxes. (messing with the door opening)
Keep your hard top on and you'll never even miss em...
If you have a full cage, tie into that and call it a day.
http://i639.photobucket.com/albums/u...kersupport.jpg
vtblazer is offline   Reply With Quote
Old 11-28-2013, 12:06 PM   #5
Ole Beater
Im thinking of building something similar to whats above. But I think the floor is boxed to prevent flexing in the floor, to stop the firewall from moving forward and backward, and to stop tha bed sides from flexing inward. So I am going to tie all three together. I may consider adding a brace inside the cab extending from the side to the floor behind the seats, similar to what I have seen on here.
Ole Beater is offline   Reply With Quote
Old 12-03-2013, 11:10 PM   #6
wannabefastcrf
Do you think if you added a brace to the fire wall from the engine compartment it would eliminate the firewall flex. Here is a picture of what I seen that was not designed for that purpose but made me think it might be extremely beneficial. Or do you think if custom inner fender to firewall braces were made and installed it would help?
wannabefastcrf is offline   Reply With Quote
