Old 10-21-2013, 11:07 AM   #1
blackgold
positive camber
I just did a disc brake swap on my 70 c10 with 2 1/2" drop spindles. I
Put on a set of 2010 silverado stock wheels and now I have positive camber. I didnt have any before and the spindles are suppose to keep all the geometry the same. So im wondering if anyone knows why this has happened. I did take all 3 shims out of the front on the control arm and 2 out of the 3 on the back. It helped alittle. My guess is that the original springs in the front are just so old that they have saged some and is causing this. I wouldnt think it would be the wheels. If anybody has an idea let me know I would appreciate it. Thanks.
blackgold is offline   Reply With Quote
Old 10-21-2013, 12:09 PM   #2
SCOTI
SCOTI's Avatar
Re: positive camber
If you swapped in new springs, yes on the possible sagging w/the old units.
Despite drop spindles 'not changing position of things' other than the spindle shaft itself, many times the steering arm isn't exactly in the same spot so re-aligning is required.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-21-2013, 12:26 PM   #3
BMERDOC
BMERDOC's Avatar
Re: positive camber
Do you mean positive camber or negative? If the front springs sag they will cause negative camber. Pulling the shims should have helped. Put up some pics of what you are seeing.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-21-2013, 10:39 PM   #4
blackgold
Re: positive camber
The old spring are still on the truck. I havent gotten it re alingned yet and yes its positive camber. The top of the wheels stick out a bit further than the bottom. Ill post pics as soon as I can
Old 10-22-2013, 12:11 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: positive camber
Get it aligned.
I bet the toe is way out also.
Keith
Convert to disc brakes.
Old 10-22-2013, 12:36 PM   #6
blackgold
Re: positive camber
I planned on getting it aligned but havent had the time yet. Once I do ill let you guys know if that fixed the problem which im hoping it does. Thought it could be something else so guess ill find out. Thanks
Old 10-22-2013, 06:19 PM   #7
BMERDOC
BMERDOC's Avatar
Re: positive camber
I don't know what machine your Aligner uses but I've been messing around with them for a while. Turns out that some of the latest machines take all the thinking out of aligning them. Even don't have that option its still a good way to go. I did a lot of research and in the end it came down to this..
http://67-72chevytrucks.com/vboard/s...d.php?t=582187
You did good by removing shims but if toe was in good shape before, it'll definitely change if you remove shims. It'll cause toe out.
Nick Carter
Old 11-08-2013, 09:49 AM   #8
blackgold
Re: positive camber
Thanks for all the info. I finally got to take it in for an alignment and they told me that they couldn't do it until I got a new idler arm, pitman arm, and upper ball joints put on so I just ordered them and got them in wednesday hopefully I will have time sometime in the next couple of weeks to put them on then finally get it aligned. Which the ball joints being totally wore out could be some cause of the camber.
Old 11-08-2013, 09:53 AM   #9
Bigdav160
Bigdav160's Avatar
Re: positive camber
No, the weight of the vehicle bearing down on the suspension will always cause it to go negative. Those steering components don't have any effect on the camber either.
I think you need a better alignment shop.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-08-2013, 11:22 AM   #10
SCOTI
SCOTI's Avatar
Re: positive camber
x2 or the summary above left out other details unless he was just recommending doing the BJ's because of excessive wear & 'suggested' the other items (I would generally suggest replacing everything too).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-08-2013, 12:22 PM   #11
blackgold
Re: positive camber
They just said I would need to replace them before they can do an alignment which the ball joint are wore out. Better to do it now than later. Once I do and get it alinged ill find out if there are still any issues. Thanks for the info guys
