Old 10-21-2013, 02:35 PM   #1
Joe69C10
Joe69C10's Avatar
87 GMC Sierra power brake master cylinder bore size?
Hey guys, just picked up am 87 GMC over the weekend. Brake pedal if very mushy, pedal travels very far, and it seems to stick or come up slow.
I was thinking about replacing the master cylinder and re-bleeding the system.
Autozone.com sells 2 with different bore sizes. 1.57 and 1.41 Bore. Besides this they both look the same. Does anyone know which one would work best? Or should I remove the one that's currently on the truck to verify?
Thanks!
Joe
Joe69C10 is offline   Reply With Quote
Old 10-21-2013, 04:13 PM   #2
D13
D13's Avatar
Re: 87 GMC Sierra power brake master cylinder bore size?
Look at your brake code on the SPID in the glove box. Bore size is relted to braking power which is given by the code, JB_ usually is the first two letters.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-22-2013, 09:35 AM   #3
Joe69C10
Joe69C10's Avatar
Thanks! I checked out the sticker in my glovebox. Code says 9J50. So is this considered the JB5 brake system?
Old 10-22-2013, 10:24 AM   #4
Keith Seymore
Keith Seymore's Avatar
I happen to have the brake system release chart for a 1987 R truck:
Your brake code of J50 (the "9" is a dummy code/place holder) would equate to JB5.
The master cylinder bore diameter looks to be 28.6 mm, which would be 1.12 inches...which doesn't match either of the Autozone offerings...
I wonder if they are measuring something other than the internal bore - like the external diameter that mates with the booster. Those vary on whether the
master cylinder is QTU (Quick Take Up) vs Non-QTU.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-22-2013, 10:50 AM   #5
Joe69C10
Joe69C10's Avatar
Thanks for the info! I just checked Advance Autos website and they offer two units. (For JB1 & JB3 brake codes) Measuring 1" & 1.13" diameter.
Looks like the 1.13" JB3 should be the one I need right?
Heres the link to it.
http://shop.advanceautoparts.com/web...new#fragment-2
Old 10-22-2013, 12:16 PM   #6
Keith Seymore
Yes - based on my chart the JB3 and the JB5 use the same master cylinder. JB1 is manual - you don't want that.
That chart is what we referred to in order to release parts for production. It was the "gold source" for all the other documents that flow from it (service releases, for example).
K
1979-1986
1986 - 2019
Old 10-22-2013, 12:54 PM   #7
Joe69C10
Joe69C10's Avatar
Great! Thanks again for the help!!
