10-21-2013, 04:10 PM | #1 |
M465 and clutch questions
Greetings
A couple of questions re my very recently acquired 71 C10 with a 250 ci: How much oil do I need for a M465 fluid replacement and is non synthetic 75-90 GL5 OK? There isn't a clutch fork return spring on this truck and the clutch fork rattles a little bit. Just checking that there really is supposed to be a fork return spring on this truck. ??? thanks! JohnG |
10-21-2013, 04:52 PM | #2 |
Re: M465 and clutch questions
It takes 6 pints (3Qts.) of trans grease. 75/90 GL5 is fine. Synthetic is not nessesary.
There should be a return spring on the clutch fork. |
10-21-2013, 05:00 PM | #3 | |
Now, I just need to find a spring. MUCH better solution than RR'ing the clutch throw-out bearing. cheers JohnG |
10-27-2013, 11:20 AM | #4 |
Greetings Again
Just an FYI: I drained the M465 and found that it had about 4.2 quarts of old fluid. I leveled the truck and the refill took just a tiny little less than 4 quarts. cheers JohnG |
10-27-2013, 02:22 PM | #5 |
here's a picture of the spring you want
you can see it going from the throwout arm to the chassis mark
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
10-27-2013, 02:32 PM | #6 |
If you do some checking, I was surprised to find recommendations to use a good quality 50W motor oil ? This transmission is built like a "Brick S$@T House" it also has manny small oil passages that Need clean oil . I just serviced one in. K-10 that sat for 10 years, drained it, pulled the shifter of and filled it with Mobil 1 15W50 and added one bottle of Lucus Oil Stabilizer. Works perfect and no gear noise at all........
71 C-20 07 Magnum RT AWD |
10-27-2013, 03:18 PM | #7 | |
I refilled the trans with a high end ML5 80/90 gear oil. cheers JohnG |
11-02-2013, 12:19 PM | #8 |
Does anyone know the part # for the clutch return spring for a 71 C10 with the M465?
thanks JohnG |
