10-21-2013, 04:26 PM | #1 |
Adding Brake Fluid
Ok totally stupid question but what is the easiest way to add brake fluid to the stock master cylinder on a 59 PU?
10-21-2013, 05:03 PM | #2 |
Re: Adding Brake Fluid
Lift carpet or matt. Remove round cover in cab floor. Remove cap from MC. use long neck funnel or squeeze bottle with hose to put in fluid. Replace cap. Pump brakes, remove cap and check again. Do not pump brakes with the cap off unless you like cleaning up fluid all over your under carriage and repainting when it eats off the paint!
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
10-22-2013, 10:17 AM | #3 |
or buy a brake fluid filling bottle, climb under neath and fill it up
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
10-22-2013, 10:59 AM | #4 |
^ that is the way !!!
10-22-2013, 01:19 PM | #5 |
if it's stock, do like orrieg suggests
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
