Old 10-21-2013, 06:31 PM   #1
Undone
LS 24 tooth to 58 tooth reluctor
Anyone know what it takes to replace a 58 tooth reluctor engine with a 24 tooth reluctor engine?
Undone is offline   Reply With Quote
Old 10-21-2013, 06:49 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS 24 tooth to 58 tooth reluctor
An engine hoist?
Do you want to put the whole engine in and swap everything over to the 24x setup?
OR
Are you trying to swap the engine but change the 24x setup to run the 58x equipment.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-21-2013, 07:27 PM   #3
Undone
Originally Posted by BR3W CITY View Post
An engine hoist?
OR
Swap engine but change 24x setup to run 58x equipment.
Old 10-21-2013, 08:18 PM   #4
Angryman117
You will have to swap the crank to a 58 tooth crank, a new sensor on the block and possibly a different ECM, not sure if you can change a computer from 24x to 58x with a tuner. If you have all the 24x stuff I would run that.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 10-21-2013, 09:04 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
or
http://www.lingenfelter.com/mm5/merc...3#.UmXO8_mgnQY
Probably a little easier than swapping the crank.
Edit; this only works for the down conversion, so running the GenIV wiring in an older setup.
What are you trying to install that requires a 24x reluctor? That would mean your currently running a NNBS truck, or GENIV wiring, but installing the older ls series into the truck?
Help me understand here a bit.
Otherwise; yes, swapping the crank /crank tigger etc would be the result.
Old 10-21-2013, 09:29 PM   #6
Undone
I have a 2007 GMC 2500 pickup with 6.0 58x that I would like to pull and use in a 71 pickup and replace it with a 2002 5.3 24x that I have. Just trying to decide if its worth the trouble or expense.
Old 10-22-2013, 12:58 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
why not just put the 5.3 in the 71 and leave your fully assembled truck....just, that.
Old 10-22-2013, 10:19 AM   #8
Angryman117
That would be less of a headache and cheaper too.
Angryman117's
47 Chevy Build
