Old 10-21-2013, 09:17 PM   #1
rich67
rich67's Avatar
key switch not working
can u start a truck without thedash cluster in it? i have power to my red wire at switch but nothing when i turn the key. there is another large pink or faded red wire coming ot of the switch that is hot when i turn key on. im still tracin down wires to make sure all hooked up. is there two small wires that come off the starter or just the purple one? if i sound dumb its because occasionally i mite be. lol tryin to learn.
rich67 is offline   Reply With Quote
Old 10-21-2013, 09:58 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: key switch not working
There are wiring diagrams posted(the gallery is down so I can't post a link)that should help sort your wiring.Remember to plug the oil pressure line or you'll have oil everywhere.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-21-2013, 10:30 PM   #3
rich67
rich67's Avatar
yeah i saw those. have a guage on oil line but thanks. ive turned truck over by crossin the starter. really just was wonderin about havin to have the dash bezel plugged in to start it or not. thanx again.
Old 10-22-2013, 10:16 AM   #4
turp mcspray
turp mcspray's Avatar
Unplugging the dash bezel, will have no effect on starting or running.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-22-2013, 12:22 PM   #5
rich67
rich67's Avatar
thanx turp.
Old 10-22-2013, 05:42 PM   #6
rich67
rich67's Avatar
when i turn on key i have no power to the purple wire. i found some plugs not connected. almost looks like i mite be missing an under dash harness or something. two bigpurple wires with plug on the end. light green and dark geen with a plug. looks like an orange and a white wire with a plug on the end. and wires off my brake switch arent hooked up either. any input appreciated. signed lost. lol
Old 10-22-2013, 07:02 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Do you have the junction block on the passenger fender with a Red wire from the positive post on the battery going to it? The White arrow is pointing to it in the picture below...
LockDoc
Leon
Old 10-22-2013, 07:33 PM   #8
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
the two purple wires with the plug go to nuetral safety switch. You'll need to put a jumper across those to get power to purple at the solenoid. But, make sure it's in park before you start it!!!!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-22-2013, 08:13 PM   #9
LockDoc
LockDoc's Avatar
As dale said plug with purple wires goes to Neutral Safety Switch, Plug with Orange and White goes to brake light switch, and plug with light/dark Green goes to reverse light switch. The NSS/reverse switch is located at the bottom of the steering column and the brake light switch is located between the pedals.
LockDoc
Leon
Old 10-22-2013, 11:31 PM   #10
rich67
rich67's Avatar
thanx everybody for the help! terminal block was hooked up. hooked brake switch up. apparently im missing the nss/reverse switch. jumpered purple plug and vroom vroom! awesome! thanx again!
Old 10-23-2013, 10:16 AM   #11
LockDoc
LockDoc's Avatar
Glad to hear you got it going. You should be able to pick up the switch at your local auto parts store. They may have to order it for you though.
LockDoc
Leon
Old 10-23-2013, 10:21 AM   #12
Ol Blue K20
Glad we could help, now get a switch and plug it all in.....
Dale
