Old 10-21-2013, 09:33 PM   #1
true74enduro
85 chevy k10 brake question
Hi I have a question I got an 85 chevy single cab Lwb 305 motor.
How low to the floor does your brake pedal get? Mines gets almost maybe about 4" away. I've bled my brakes changed pads. Is that normal? Could I not be getting vacume
true74enduro is offline   Reply With Quote
Old 10-21-2013, 09:58 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 85 chevy k10 brake question
check and lube the ajustment on the rear shoes,it should bring up the pedal
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-22-2013, 12:34 AM   #3
true74enduro
Just with the rear shoes not being ajusted will make that much of a difference? The forms do 90% or braking almost oh well this doesn't seem like it should be this low ill ajust them
Old 10-22-2013, 07:40 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
yes it should bring up the pedal,the pinwheel @ the bottom between the shoes,clean and lube with the right brake grease
it normally ajusts this low pedal,when backing up,till the ajuster seizes up
John
Old 10-22-2013, 09:33 AM   #5
true74enduro
Awesome I will try it
Old 11-14-2013, 04:34 PM   #6
true74enduro
I ajusted my back drums to try and bring up the pedal nothing same old low pedal. And ideas I purged the system the ole two people bleed process
Old 11-14-2013, 08:28 PM   #7
donut
donut's Avatar
Try to press and hold the brake pedal, see if it sinks further. (bad master?)
Does the e-brake work? If it was adjusted and works, then your rear brakes were/are in the ballpark. If setting the e brake helps your pedal, then you still have more work to do on your rear brake adjustment.
Do you have a dirt driveway? do a slow roll and slam on the brakes, get out. did it leave 4 skid marks? (it should.)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 11-14-2013, 08:36 PM   #8
true74enduro
Thanks donut I'll try that I noticed my brake fluid is kinda darker tan than normal fluid does that mean anything
Old 11-27-2013, 09:11 PM   #9
true74enduro
I changed out the mastercylinder and of course the fluid it raised the pedal a lil more to my liking. I might now change to discs in the rear just for the ease of maintaining. Has anyone here used a early to mid 90s camaro caliper and bracket on the back with a 6 lug rotor I was thinking if using a 88 k1500 rotor on the rear
