Big back window conversion?
Hey all I recall one member taking this on but not sure what the result was. Has anyone performed this conversion? How did it come out? I imagine this would be a huge undertaking. Curious if it's really possible.
Re: Big back window conversion?
I think there is one in the projects/build threads section but may be mistaken.
Unless the rest of my cab was nearly perfect I think I would just consider getting a decent big window cab and prep it, paint the interior, put what ever coating on the bottom and swap cabs.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 10-22-2013 at 10:08 AM. |
![]() Join Date: Jul 2009
I think you are referring to thump16's thread.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
Look at this thread, done right.
http://67-72chevytrucks.com/vboard/s...528853&page=10
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#5 | |
Yes sir I was, come to think of it and I can't think of a better tutorial to send someone who is considering doing it to. It also will very quickly let a guy or gal figure out if they are up to the task and want to undertake it.
looked thru thump's bbw conversion again.
$1200 in parts and a lot of work but the finished product should look good, when he finishes it. plus you get all new cab corners in and out ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
I think, when the time comes, I will take on this challenge.
I'm considering it too, but getting rid of the straight axle is next on my priority list.
My uncle is doing the conversion right now on a 66. The catch is that gm produced 3 cabs at the time. One was only for the small window (the truck he has). One was produce only for the big window. And a third had the small window but was designed so that you could cut the cab out for a big window. He found the third cab. It requires a lot of prep work but win carful cutting its by far the best way to go.
I had to stop work on my conversion due to my fathers brain cancer surgery. He is alive and well on the way to a healthy recovery considering his tumor was the size of three golf balls.
As far as the conversion itself, I have everything prepped and ready to weld in. Instead of using my small inner window frame I opted to use the one piece inner window and pillar.http://67-72chevytrucks.com/vboard/a...1&d=1352858580 So if anyone needs the inner window frame support Pic below, I have one in the attic.http://67-72chevytrucks.com/vboard/a...1&d=1352857140 Last edited by thump16; 10-27-2013 at 09:50 AM. |
Thump first and foremost Godspeed to your dad and all the best with his recovery . Do keep us informed about the progress you make with the conversion.
