Rust prevention! bed liners?? do or don't ? thoughts??
I have a lot of surface rust covering the bed area. Was thinking how to go about handling this. Do I grind and treat with some type of rust prevention product.
What are somethings that have worked for you. I'd like to keep the original color if possible. I have used Por-15 on a frame in the past. Some small use with Eastwood rust converter and encapsulator. I like the look of Monstaliner from Magnet Paints. I also love working with Hammerite products.
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
![]() Join Date: Oct 2012
Re: Rust prevention! bed liners?? do or don't ? thoughts??
unbolt the bed sides and front and have the bottom sandblasted and powder coated ..............
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
Kill Bill...et
If you spray or roll in bedliner, be sure that's your final decision. That stuff is a b*($ to take out! I opted for it because I still use the truck as a truck. I used herculiner. Seems to be okay, but I'm putting in aluminum strips to break up the monotony for a foux wood look. Good luck with your project!
US Army Veteran
![]() Join Date: Nov 2008
I laid down bed liner (Gator) in my '72 about a year and a half ago. It's already peeling up on the bed floor. Granted, we live ten miles from hell and see five to six months of 100+ degree days here.
It's fine on the tailgate and inner panels, but in the battle of the hot Texas sun vs. the bedliner, that Texas sun won. At some point, plan to scrape it up, clean it up, and lay down POR or Bill Hirsch type paint.
1972 C10 Highlander - The making of a daily driver |
I had Gator liner sprayed by a shop in 2008. The inside of the bed was cleaned up and primered by a body shop prior to the bed liner installation and it has held up well. I've had no issues and my truck sits on the street - it sees most weather conditions.
![]() Join Date: Oct 2011
I'd forget about the spray in rubber coating stuff for the moment....you're more than likely to start a rust problem with that stuff without a lot of preparation, etc.
So, how about get in the back and sand it down as close to the original metal as possible and then clean/blow it out, wipe it down and spray in/apply a good quality etching primer. After that you could spray in the factory colour. If you aren't too fussy about the inner bed area you don't have to drop a ton of dough into having a body shop do it if you have access to a compressor and a sprayer yourself. ![]() A lot depends on how much time, money and the facilities you have to work with. My two bits. Coley ![]()
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Like was mentioned above, take the bed apart and get it blasted and etch primed first to take care of the rust, doesn't matter of its surface rust or cancer if you cover it its still gonna get worse, the biggest problem is where you cant sand at all the seams where its bolted together.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I like the durability of the bedliner, but don't like the dirt they collect.
Here's a picture of my rusty bed, the rust really isn't that bad. But I would like to get it gone. I was thinking of having it sand blasted, leaving the bed on the truck. Then rattle can etched primer, and color code it the best i can to the original stock color. I'd like to have the distressed look if possible. I don't see a lot of colors offered that are yellow.
If you do that there will still be rust between the panels where bolted together, that rust will continue to get worse over time regardless of the bed liner. But if you were going to do it anyway then you need to at a minimum get some phosphoric acid and coat the hell out of the seams and hope it creeps into all the crevices, it will at least slow the rust down a little.
#10 | |
Do some good prep work on any rust areas and then spend some money on a good spray in rino has worked great for me. On my 70 I left the bed caps painted and sprayed everything below. I will agree with what has beem said before it is a pain to remove. I did make sure the bed bolts were out so I can remove the bed from the frame if needed but the bolts for the bed sides are sprayed over.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#12 | |
It's a little pricy, but this place will mix up factory color and put it in a spray can for you. I just bought a couple cans to trim out my new doors and fender before I put them on the truck. What sets these guys apart is you can lacquer, acrylic enamel, base/clear. Most of the spray bomb stuff is always lacquer, which is OK for touchups, but probably wouldn't want to spray the whole bed. Just my thoughts.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#13 | |
Read this thread: http://67-72chevytrucks.com/vboard/s...hosphoric+acid
#14 |
how about hammerite, has anyone had experience with this?
