10-22-2013, 12:49 AM | #1 |
Stock front airdam for 73-80 Worth picking up?
Added picture of actual air dam As a lot of you know I spend a lot of time locating and selling parts for 73-87 Chevy and GMC trucks. For the first time ever I have came across not one but two stock air dams for the 73-80 trucks. I see the 81 and newer periodically but never 80 and older. I pulled the one I found today and set it aside. The wrecking yard isn't super cheap so I don't want to spend much money if it isn't worth it. It does have a 1" tear at the bottom in the middle. I would think it would be short work to repair. Thinking about getting it for my own truck. It will give the illusion of it sitting lower. It looks like the one in this picture.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. Last edited by 1774btcrew; 11-04-2013 at 02:51 PM. |
10-22-2013, 12:52 AM | #2 |
GM Addicted
Re: Stock front airdam for 73-80 Worth picking up?
I picked up the last two in the gm parts system a few months ago. they are nice. truck is just too low for it. any chance one of the two is the 3 piece design??
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
10-22-2013, 01:24 AM | #3 |
I know the one I pulled today is one piece. The other one I didn't look at too closely.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
10-22-2013, 02:35 AM | #4 |
I think the correct front air damn for 73-80 is a three piece part and hard to get. Most people adapt the later model one piece air damns to these trucks and those ones mount to the bumper
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
10-22-2013, 08:08 AM | #5 |
That's my truck in that picture an that's an 81+ airdam I modified to fit... It bolts to the bumper where the correct one bolts a little further back on the frame....
Here's a correct one.. It appears that the split should be there as I doubt Ken would keep a broken one on his long. Especially since he had everything off for those upgrades....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 10-22-2013 at 08:19 AM. |
10-22-2013, 08:39 AM | #6 |
Getting Old; Going Broke
1980 was the first year of the single piece air dam and was a stand alone part.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
10-22-2013, 08:57 AM | #7 |
Thanks for the info. This Blazer was all original so I doubt it was a newer part. The picture above was referenced as it was the only 73-80 I found with a front air dam.
10-22-2013, 09:31 AM | #8 |
Did it bolt to the bumper or to the core support? They did not attaching the air dam to the bumper until 81, as already mentioned. 80 and below were attached to the core support and were less visible since they were further back.
10-22-2013, 09:44 AM | #9 |
To be honest with you, I was in a hurry and just zipped it loose with my impact so O wasn't physically under the truck not I think it was bolted to the core support. I am hoping to run back by there today to grab it.
10-22-2013, 10:48 AM | #10 | |
'80 and earlier had a flat blade under the radiator support to push air up into the radiator. '81 and later had the three dimensional air dam mounted on the bottom of the bumper to push air around the outside of the truck (and prevent it from going under). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-25-2013, 12:02 AM | #11 |
I went ahead and picked it up. It was on a 4x4 Blazer. 2 of the bolts actually mounted to the front spring hangers and 2 mounted where the inner fender well mounts to the core support.
10-25-2013, 07:31 AM | #12 |
Don't Crush em Restore em
I have an 80 and it is a flat blade type like Keith mentioned.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
10-28-2013, 12:18 AM | #13 |
I am back home and plan to try to get it mounted up this week and see how it goes.
11-04-2013, 02:51 PM | #14 |
Picture of actual air dam is now up
11-04-2013, 03:13 PM | #15 |
Do they serve much of a purpose on these old trucks? I know on some newer cars, your car will overheat without it. Found that out the hard way. But what do they do on the 73-87 trucks? I was thinking of getting a new one since mine has a couple cracks.
11-04-2013, 04:25 PM | #16 |
I don't really know since most of these trucks are missing these.
11-05-2013, 07:11 AM | #17 |
You're Welcome For The Info Btw.....
An As I Stated Earlier, The Airdam You Have Won't Look Exactly Like The One Pictured On My Truck Since It Mounts Further Back An Not Right On The Bottom Of The Bumper...
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
11-05-2013, 08:24 AM | #18 | |
Keep in mind, though, some of these parts are there because of a test result in some extreme case, like pulling a trailer at GVW up Townes Pass in the middle of the summer. You might not need it based on your duty cycle. The '81 to '87 part was added as an aerodynamic improvement. K
11-05-2013, 11:33 AM | #19 | |
11-05-2013, 11:38 AM | #20 |
Every little bit helps.
But - yes. As we moved forward and the EPA requirements became more and more stingent we'd spend a lot of money on .001 here or .001 there (and they do add up). The little "bump" feature on the nose of the '78-'80 hood? That was placed there as an aero improvement too. K
