window regulators
Is there a way to lube the mechanism to help make the window go up and down smoother? Are there aftermarket parts that i can replace existing parts? If so what should be replaced?
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
![]() Join Date: Aug 2008
Re: window regulators
You can pull the door panel and pit some grease where the gears mesh but my guess is your rollers have flat spots. That is what I have found anytime I have had the same issue. Most suppliers sell new rollers and worse case scenario you can buy a new repro regulator for under $40.
