Old 10-22-2013, 03:14 PM   #1
cg285
reproduction factory 6 cyl a/c brackets
for those that are tired of all the small blocks and think the inlines are cool:
what interest would there be for replica gm 6 cyl a/c brackets. mid 60's vintage.
i prefer the factory look myself - (even if modified i prefer the modification to look like a factory install vs an aftermarket affair. it looks more professional that way)
in the past i've had to use a later block (integral head), switching the head of course, and use the gm r-4 setup. i now have a set of original a-6 brackets i am toying with reproducing if there is an interest.
cg285 is offline   Reply With Quote
Old 10-22-2013, 03:37 PM   #2
MitchFloyd
MitchFloyd's Avatar
Re: reproduction factory 6 cyl a/c brackets
Which inline 6 cyl series are you looking at?
1. - 216/235/261
2. - 230/250
3. - 292
or all three series?
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 10-22-2013, 03:45 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
Don't forget the 194!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-22-2013, 03:47 PM   #4
cg285
mid 60's
194-292
don't know about the 235-probably not
Old 10-22-2013, 03:50 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
The 194-250 were the same block height, but had slight differences in size. The 292 has a much taller block height and is bigger. 194-250 in certain year may have been the same block I am not sure. The 235 and 261 shared the same side covers....Though I will say that repro-brackets would be cool!
Old 10-22-2013, 04:46 PM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
1963- L6 194 230 250 292 same as passenger car.
There`s no different diagram in the instruction book for 292.
1964 got a Cast Bracket?
Old 10-22-2013, 04:58 PM   #7
padresag
believe that there is a difference between the 292 and the others and that difference brings in the bigger $
ron
padresag is offline   Reply With Quote
Old 10-22-2013, 05:13 PM   #8
TJ's Chevy
TJ's Chevy's Avatar
The 292 was only produced with an alternator in all production years as far as I know so what I was getting at was the bolt holes in the block and I believe the a/c is mounted on the other side? But the 194-250 were the same. But the 292 is a whole different block, 2 inches taller on the side covers do to the 4.120 stroke. But could I get a picture of the factory version? I'm interested in seeing? Thanks. T.J.
Old 10-22-2013, 06:11 PM   #9
cg285
they dont bolt to the block
Old 10-22-2013, 06:12 PM   #10
cg285
ron
ok, then ill charge more if its for a 292
Old 10-22-2013, 10:03 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Sorry I did not know...never seen the actual set up so....
Old 10-25-2013, 03:05 PM   #12
cg285
well that tells me what i wanted to know. it's not worthwhile reproducing oem a/c brackets
Old 10-25-2013, 03:21 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Reproducing Power Steering brackets for the 250's and the 292's might yield bigger interest.
Keith
Convert to disc brakes.
Old 10-25-2013, 04:09 PM   #14
cg285
i believe there is someone doing ps brkts albeit not oem style
Old 10-26-2013, 09:06 AM   #15
60-66
60-66's Avatar
http://www.ebay.com/itm/1970-74-CHEV...#ht_391wt_1162
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
