Old 10-23-2013, 12:57 AM   #1
true74enduro
85 chevy 350 single cab heater/ defrost ?
My heater and defroster don't work well at all in my truck and I've flushed my system and changed the thermostat. One day it seemed like my heater got a kick in the jewels cause it got hot. But now today she's just runs the same cold
true74enduro is offline   Reply With Quote
Old 10-23-2013, 07:44 AM   #2
true74enduro
Re: 85 chevy 350 single cab heater/ defrost ?
Did these really have this bad of heater
Old 10-23-2013, 07:57 AM   #3
Keith Seymore
Keith Seymore's Avatar
No - the heaters were quite effective when new (or when functioning properly).
Subscribing to see what the guys have to say about your situation. If you've flushed it (and it's properly filled - no air pockets) then you've done what I would do.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-23-2013, 08:50 AM   #4
csdineley
csdineley's Avatar
Might try replacing the heater core. Maybe its clogged or something. But my will roast me out.
csdineley is offline   Reply With Quote
Old 10-23-2013, 09:16 AM   #5
Rubble
Any of my trucks will roast you out @ -30 deg.C . As mentioned before,your heater core could be plugged up.Are both heater hoses hot when engine is up to temp? Also your fan motor might not be moving as much air anymore too.I just changed out the core & fan motor in my crew& made all kinds of difference,also helped when all the mouse nest was cleaned out!!Make sure the air blend door is opening & closing all the way,this will affect it too..
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 10-23-2013, 10:59 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
I'd bet with AC?
I'd want to look at the top of the air box,
and by the gas pedal
some of the flaps are vac controlled
can you hear movement with the cables?
does the def/heat selector change the air flow? up/down?
I get lots of heat,but i do run a rad cover ,get heat quicker
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-23-2013, 12:42 PM   #7
true74enduro
Yes my truck had ac as well. Thanks guys I'll try the heater core both radiator hoses are hot when engines been run
Old 10-23-2013, 06:03 PM   #8
true74enduro
I can hear some movement in cables not a ton.
Old 10-23-2013, 06:44 PM   #9
nekkidhillbilly
blend door id say is sticking. yes these old trucks would roast your a$$. my 01 and 04 never heated as good as the squares or even the 88-99 cks.
nekkidhillbilly is offline   Reply With Quote
Old 10-24-2013, 10:41 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
do you get air out the AC vents and heat/defrost at the same time
does changeing the switch make a difference?
if I remember it's only a couple of screws to pull that tube for the dash vents off the front
John
Old 10-24-2013, 12:00 PM   #11
true74enduro
Not a fair difference from
Hot to cold no where normal I mean it's still cold.
Old 10-24-2013, 12:02 PM   #12
true74enduro
I'll have to check the defrost vents. I know how to pull the tube off that connects to the heater. After I do that what next?
Old 10-24-2013, 10:29 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
I was thinking of air "flow" does it move as selected
just undo the bolt you see and you need to push the pin out
John
Old 10-25-2013, 12:48 AM   #14
true74enduro
Now there isn't much change in heat flow at all on the controlls.
Old 10-28-2013, 03:27 PM   #15
true74enduro
I noticed today when driving my truck with the heat off I was getting cold air comming in. I dunno if that helps to figure out my problem
Old 10-28-2013, 04:05 PM   #16
willett
Another Day, Another Dollar
willett's Avatar
Are your kick panel vents closed?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 10-28-2013, 04:30 PM   #17
true74enduro
I felt behind my left kick panel and it was open when I turned my heat on but I didn't check when I was getting cold air
Old 10-28-2013, 06:07 PM   #18
true74enduro
Motornut my selector does work as selected slight differences in heat to cold
Old 10-28-2013, 09:20 PM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
AC trucks may only have one cowel or foot vent, on the pass side,again controlled
by vacume.if it's not closed it could be coming in there .
could put a manual one in or wire it closed, work back, might find a leak.
John
Old 10-29-2013, 01:32 AM   #20
true74enduro
Ok. As for heat what do you think might help me get the truck hotter?
Old 10-29-2013, 06:04 AM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
is that blend door working ok?
John
Old 10-29-2013, 12:44 PM   #22
true74enduro
as far as I can tell it opens shuts
Old 10-29-2013, 04:14 PM   #23
motornut
78K & 79C Jimmys
motornut's Avatar
ok
did you remove it and look, or going by sounds like it's moving
I'm asking about the air flow first, not the temp
when you switch the settings of "flow" to the defrost,heater,dash vents
does it change right and stop where it shouldn't be?
the defrost/heater (can be set to leave 1/3 up or down)
more important the dash vents stop flowing,when the def/floor setting goes on
and the def/floor stops when the dash vents are used,try max too(hot or cold)
either way it's sounding like the heater core/air box has to be pulled
John
Old 11-17-2013, 05:17 PM   #24
Willie496
Where is the blend door in my 82 C20?
My A/C is gone (disconnected) and the hot air only goes to the floor not the defrost when I move the lever to defrost. Any help would be great!
Thanks,
Willie
1969 GMC 4x4, 4 speed, 350 Fleet Side in progress.
1969 Camaro SS 427 Cortez Silver. owner since 1974
1964 Chevelle 4 Door, 427 Big block,Turbo 400
1/4 Mile 10.52 @ 125.85 mph. 1.39.1 60'
1982 Crew Cab 3+3, 2WD 3.21 Locker, 468/4 speed
1969 C30 4 speed (IL6) future build.
Willie496 is offline   Reply With Quote
Old 11-17-2013, 07:25 PM   #25
motornut
78K & 79C Jimmys
motornut's Avatar
Thanks,
Willie
in post 6 are pictures at the blend door
John
