Old 10-23-2013, 01:28 AM   #1
frankyjoet
Unhappy push button setup to start engine
need help or suggestions to install an aftermarket push start button setup on a 73 gmc pkup. have pics of the kit.
frankyjoet is offline   Reply With Quote
Old 10-23-2013, 08:00 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: push button setup to start engine
One wire goes to the starter solenoid and one wire goes to B+. I assume you've got a third wire for the button to light up.
I've got this setup on two of my vehicles; My '63 GP and my '74 Chevelle. In both cases I mounted the button in the ashtray in place of the cigarette lighter.
Turn key to "on"; push button to crank.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-23-2013, 05:49 PM   #3
frankyjoet
Thanks, keith. i have 4 wires coming from the relay. According to directions i have, the (red) goes to b+ constant. the (white) wire from relay goes to the starter wire by cutting the starter wire and reconnecting the white wire to the starter end. Is the (yellow) wire coming from the relay needed to connect to the key cylinder wire? Can i connect this wire to the ignition sw wire or is this wire necessary? The pics show the 4 wires. the 4th wire Blk goes to rear of the button coming from the relay and also a grnd wire to chassis. thanks for any help.
Old 10-23-2013, 06:14 PM   #4
nekkidhillbilly
you can also get a set up thats like new cars no keys and has to have a fob or something in your pocket to start
nekkidhillbilly is offline   Reply With Quote
Old 10-23-2013, 10:12 PM   #5
Skunksmash
Skunksmash's Avatar
Off topic, but I want a finger print reader? No finger print, no start!
Skunksmash is offline   Reply With Quote
Old 10-24-2013, 07:31 AM   #6
Keith Seymore
I didn't interact with the key switch or wiring in any way. So mine is more like a "bump" switch (like you would use for lashing valves). It merely provides the crank function and the ignition still works like it did previously.
K
1979-1986
1986 - 2019
Old 10-24-2013, 02:56 PM   #7
nekkidhillbilly
prob could be done you would need a usb fingerprint scanner and a computer to fire the truck. wouldnt be hard but would be easy to fault up. you could also use a phone that has the fp scanner and wifi or bluetooth to send a signal to engage the starter. still would need a computer in the car and you would have to sync it up. alot of headache to start a car.
