10-23-2013, 02:42 AM | #1 |
Lowered 75 C10 long bed
Finally convinced myself to get a start on this monster! First off its a 75 with 81k original miles. Motor is a 350 with auto trans.
To start off I started with replacing the body panels that were rusted out, and added a rear axle flip kit and 1.5" off springs in front. Next up is my 2.5" drop spindles and shocks from Lmc and rear shackle set with c-notch on the rear. I am in trouble when it comes to my cab repair panels, without knowledge of welding and how exactly these are replaced. My most important task before paint. And I am wanting to fit 22s possibly 24s depending in how wide I can go, and how low. Anything thoughts? Please share Last edited by Chrisxeasy; 10-23-2013 at 02:44 AM. Reason: Adding description to title |
10-23-2013, 02:43 AM | #2 |
Re: Lowered 75 C10
And another
10-23-2013, 07:41 AM | #3 |
Re: Lowered 75 C10 long bed
looks like a good start I like the factory white and green two tone with white top. looks like you may have some camber issues on the driver front. from the pictures it mostly looks like rocker panels that need work and you don't have to be a good welder to spot weld just take your time drill the factory spot welds pull the old one put on the new and re spot weld after double checking placement a hundred times.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s |
10-23-2013, 09:04 AM | #4 |
Welcome to the Forum!!
Looks like a good start to be a great truck! Enjoy the truck there a blast. My only other comment to add about welding is if your very unsure of your welding skills before you try and tackle it on your trust made do some practice testing, just so that you're more comfortable with it.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
10-23-2013, 12:48 PM | #5 |
Lower rocker panel rust to replace
10-23-2013, 01:04 PM | #6 | |
10-23-2013, 02:50 PM | #7 | |
You could get narrower lower arms. Spindles wont correct it but just lower it more. If you put the original springs back in and did spindles then you wouldn't have the camber issue.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-23-2013, 04:21 PM | #8 |
Good looking truck. I like the paint scheme and I also like the thin whites. I'm old school....lol. I've got my fair share of rust to tackle but you can do it or find somebody willing to help.. Good luck.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
12-03-2013, 12:08 PM | #9 |
Did u have to notch when u flipped leafs? If not, will for sure huh w shackles?
12-04-2013, 01:22 AM | #10 |
12-05-2013, 11:22 AM | #11 |
got any pictures of the axel flip?
12-08-2013, 12:44 AM | #12 |
Here is before c notch which wasn't too hard at all
12-08-2013, 12:44 AM | #13 |
C notch in
12-08-2013, 12:45 AM | #14 |
2 inch shackles
12-08-2013, 01:43 AM | #15 |
Very good pictures, thank u. Who'd u buy notch plate from? Maybe u made it? Think ill flip first like u. Dont know what the notch kit costs but looks like welder neighbor could fab me one up. Flip kit is just u bolts and some kind of axel pad? Thanks again. (trying to send som pics but been waiting 10 min? to upload. ill try again later
12-08-2013, 10:15 AM | #16 |
Not sure if it matters but I am pretty sure your shackle is on backwards. Nice progress!
If you live in Oklahoma click this link |
02-01-2016, 01:58 AM | #17 |
Any more progress? You have a similar truck to mine, and I'm just about to get started on my project. Great pics!
