Old 10-23-2013, 04:11 PM   #1
Primed67
Primed67's Avatar
59 Chevy frame swap
Ok I haven't been on in a while because I sold my 67. I found one hell of a deal on a 59 1/2 ton Apache swb step side. I've done a little research and I see people talking about doing a frame swap from a s-10 but I was told that a frame out of a late 70's to early 80's frame would work with little work. I just wanted to get opinions on what would be the easiest? Thanks for the help!
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 10-23-2013, 05:55 PM   #2
Rude Dude
Rude Dude's Avatar
Re: 59 Chevy frame swap
Look at the top of the page sub forum "labeled projects & builds" there are some trucks using the frame you are discribing
Rude Dude is offline   Reply With Quote
Old 10-24-2013, 12:56 PM   #3
akdg87
akdg87's Avatar
72 c10 frame. May have to do a bit more research on the front weel offset. Im going to run a skinnier tire but these tires were just to get it rolling around.
akdg87 is offline   Reply With Quote
Old 10-24-2013, 01:19 PM   #4
Daze57
Daze57's Avatar
^ nice lookin truck !!!
Daze57 is offline   Reply With Quote
Old 10-24-2013, 01:27 PM   #5
dubie
dubie's Avatar
you could use an S10, but you'll have to shorten the frame, make up or modify all your cab mounts, raise your bed floor and use spacers to move your wheel out further.
The 73-87 chassis will work but the track width is much wider than stock which means you can't lower it a great deal. EZ Chassis Swaps make a kit to adapt the 55-59 body onto a 73-87 Chassis.
Or you can put it on a car chassis like a Caprice.
Personally, if your frame is in good shape, I'd buy a 2md generation Camaro and weld on the front clip from it
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 10-24-2013, 01:32 PM   #6
Daze57
Daze57's Avatar
gettin snowed in yet? ^
Old 10-24-2013, 03:03 PM   #7
_Ogre
_Ogre's Avatar
use the stock frame and modify it, is the easiest and usually the least costly.
all new mustII, 40 yr old camero clip or lots of other options up front.
flipped axle on stock springs, 4 bar, 3 bar w/ panhard or lots of options out back.
either one is easier than a frame swap and your much more likely to finish it.
read some of the builds here, most tf truck builds have the stock frame under them.
shop air compressor timer
Old 10-24-2013, 03:03 PM   #8
dubie
dubie's Avatar
no snow yet buddy, well, nothing that stuck around for any amount of time. it's coming soon though
Old 11-01-2013, 12:58 PM   #9
slydogg76
Nice lookin, solid truck! Keep it up!!
slydogg76 is offline   Reply With Quote
