Old 10-23-2013, 07:12 PM   #1
robert_63
robert_63's Avatar
20 lb radiator cap? 5.3 ls swap
I have a question, I'm using my stock radiator for my 85. I bought a new cap. A 13 pr 16 lb I believe, and it wouldn't seal to the radiator it wouldn't pressure up just blow out . I stepped up to a 20 lp cap just to try it and it sealed like it supposed to, what I'm asking is. Is this too much? I don't know anything about the lb rating of a radiator cap or the system pressures required, all I know is the 13 lb cap wouldn't seal off and I figured it wouldn't work
robert_63 is offline   Reply With Quote
Old 10-23-2013, 07:32 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 20 lb radiator cap? 5.3 ls swap
Hmm, I had that issue with the 13lb but went to the 16lb and all was good
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-23-2013, 07:59 PM   #3
whitels1
whitels1's Avatar
How is your cooling system plumbed?
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 10-23-2013, 08:32 PM   #4
cdowns
cdowns's Avatar
a 20lb cap is a great way to blow out your heater core
Old 10-23-2013, 08:41 PM   #5
robert_63
robert_63's Avatar
It's plumbed with factory 85 radiator steam line tapped into top of water pump . The lower pressure cap wouldn't seal off think it was a 13 lb one from autozone
Old 10-24-2013, 08:13 AM   #6
solidaxel
solidaxel's Avatar
Is the neck of the rad in good shape, no nicks or erosion, hav it checked.
Like he said 20# on the heater core is bad news!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-24-2013, 08:29 AM   #7
robert_63
robert_63's Avatar
The radiator is in good shape. I probably just got a cheap part that didn't fit right. Going to go to napa and get a different brand of cap and see
Old 10-24-2013, 09:13 AM   #8
ls1nova71
ls1nova71's Avatar
Are you using any kind of overflow bottle? 16lb with overflow bottle is what it would have been stock if I remember correctly and should work fine.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-24-2013, 02:43 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I run an overflow on a sbc rad, with a 16lb cap. No problems whether coolant or water.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-25-2013, 04:06 PM   #10
Robznob11
Robznob11's Avatar
Its also good to know that the higher the pressure the higher the boiling point of the coolant. If you do boil over with a 20 lb cap the coolant will be so hot that there will be more carnage with the motor
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
