10-23-2013, 10:50 PM | #1 |
Really could use some help on this one!
Is this a normal or a cracked case? Can it be repaired or just replace. Vehicle will make about 420hp
10-23-2013, 11:00 PM | #2 |
Re: Really could use some help on this one!
Did I order the wrong shafts or am I missing something
10-23-2013, 11:52 PM | #3 |
WOW entire housing is cracked? Never seen one that bad.
Definitely NOT repairable. Desert |
10-23-2013, 11:56 PM | #4 |
No it's done. And those arms may have thier own special part.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
10-23-2013, 11:57 PM | #5 |
Housing looks busted, but a local machine shop can magnaflux it if you're in doubt. If it is broken its scrap iron. There's no fixing that.
The control arm shafts look right, but there's no bushings in your photos. |
10-24-2013, 05:10 AM | #6 |
Thought it was done, but the weird thing is that x shaft will not fit no matter what angle I chose
10-24-2013, 09:41 AM | #7 |
Yeah the rear end housing is toast,On the cross shafts talk to michigan metal works see what he says about that.
10-24-2013, 10:15 AM | #8 |
I don't know which truck you are running but it looks to be a 10 or 12 Bolt Axle?!? If you are in the 400 HP range, I'd probably be considering at least a 9.5" SF axle for strength.
What axle do you have? Gear ratio? Truck?
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L Last edited by Ski-me; 10-24-2013 at 10:23 AM. |
10-24-2013, 12:10 PM | #9 |
if Michigan metal works is anything like porterbuilt i think they have specific shafts, might want to give them a call, my uca's shafts came with my porterbulilt arms, each company is different
like for example: Portebuilt pic Strongarms pic
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
10-24-2013, 01:44 PM | #10 |
The 8.5 ten bolt will hold a 600hp big block when built. Buick regales are running 8s with them. Pretty much good enough for me
10-24-2013, 03:39 PM | #11 |
It's a 12 bolt in an 86,now I need to find another axle shell to rebuild. I wasn't worried about if a 12 bolt would hold I know it will just was curious about that power on a crack. I also think the reason the x shafts wouldn't fit is because they are problem solving shafts
<----Christopher Oh yeah I'm really a Toyota guy, but had some stuff sitting around. Oklahoma Last edited by king-918; 10-24-2013 at 03:45 PM. |
10-24-2013, 09:27 PM | #12 |
Yes, but they are not exactly stock.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
10-25-2013, 12:33 AM | #13 |
What years can you find a 12 bolt? looks like I'm in need of a good rebuildable core
10-25-2013, 02:18 AM | #14 |
I think anything 73-87 should have it as a option.
10-25-2013, 02:35 AM | #15 |
70s trucks typically had 1/ bolts and 80s trucks got the corporate ten.
10-25-2013, 02:35 AM | #16 |
I think 81 was the last year for the 12 bolt in our trucks.
10-26-2013, 03:04 AM | #17 |
420hp but how much torque are you going to have?
10-26-2013, 07:55 AM | #18 |
Slots go on anything!
A 1/2 ton 4x4 rear 12 bolt will work as well; you just have to swap axle shafts.
1974 Jimmy- 5.3/4L80e/NP241 |
10-26-2013, 08:02 AM | #19 |
10 bolts are cheap n easy to find. 12 bolt internals fit in them with a little work and are much stronger. The cracked housing is interesting, wheel hop? or speed impact? overloading shouldn't have cracked it that way.
the arms, id go to the company you got them from the replacement part looks like its not going to fit, don't forget the 3/8 inch or so of bushing that also has to fit in the gap. |
10-27-2013, 12:14 AM | #20 |
I have 2 of them if you get back to see your relatives over the holidays & don't find one before then. I used the standard Moog shafts w/o issue so it might be the offset that is causing you trouble.
10-27-2013, 04:27 PM | #21 |
Did you get my text?
10-27-2013, 09:08 PM | #22 |
Yes I did but have been out all day. I'll give you a shout after work tomorrow?
10-27-2013, 09:48 PM | #23 |
You need a girdle! (not your grandma's) Also I would use an older 12 bolt instead of the later one. I've never tore up an older one...
10-27-2013, 11:24 PM | #24 | |
Thanks |
