Old 10-24-2013, 01:41 AM   #1
sambudo
sambudo's Avatar
Inline 6 250 4spd starter question 2part question
noticed on my solenoid there are two locations to hook up small wires, and one for the battery. I'm pretty sure the yellow wire on the left should be hooked up. Although it seems to work ok w/o it. what does it do?
Took my starter out and the starter gear where it engages with the fly wheel. spins freely. should this spin like this, or is it broken?
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 10-24-2013, 07:07 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Inline 6 250 4spd starter question 2part question
As far as the two little terminals. The purple wire goes to the one labeled "S". The yellow wire goes to the other one. If you have points ignition the yellow wire needs to be hooked up. If you have HEI ignition the yellow wire doesn't need to be hooked up.
Old 10-24-2013, 04:58 PM   #3
Wrenchbender Ret
I agree with Tex on the wires. The gear should turn in one direction only. If it spins freely in both directions it is completely shot. If it turns freely in one direction it is probably about to go out. Normally it has a drag in the one direction & wont turn in the other direction without turning the armature. If the starter spins sometimes without turning the engine it needs a new drive.
Wrenchbender Ret is offline   Reply With Quote
Old 10-24-2013, 05:03 PM   #4
Tx Firefighter
If it needs a new drive, you can get one at the parts store. No reason to turn your working starter in on a junky rebuild that the parts guy is surely gonna try and pawn off on you. Drives are cheap and easy to replace.
Old 10-25-2013, 12:40 AM   #5
sambudo
sambudo's Avatar
do i ask for a drive for the starter
? thanks for the info.
Old 10-25-2013, 02:33 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Accel sells a US-made Starter Solenoid, that is an exact replacement.
Old 10-25-2013, 05:10 AM   #7
Tx Firefighter
Yes. Ask for a starter drive. I usually look them up at the parts store website and have my own part number. Saves having to trust the counterman.
