Tricks for removing bench seat?
I have a full set of replacement seat belts on order and I doubt that I can get the old ones out and the new ones in without removing the stock bench seat. With that being said, every time I try to do something on the truck it turns out to be harder than I anticipate - I already anticipate the task to be a pain.
Are there any tricks to removing the bench seat?
Hook'em |
Moderator
![]() Join Date: May 2007
Re: Tricks for removing bench seat?
Remove bolts. Remove seat. Very easy and straight forward. May need PB blaster or some other penetrating oil to remove the seatbelt bolts, they can be a pita sometimes.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Band aid and a shot of jack incase you bust a knuckle... actually the shot of jack has multiple uses... you may want it for after you remove the seat for a job well done.
71 swb 350/4sp manual 5/7 static drop |
Should be no problem, go out the passenger side with it though! I live in the Round Rock!
#5 | |
![]() Join Date: Sep 2010
Might want someone else there for the removal, as not to mangle the paint dragging it out. What zepp said, squirt the bolts ahead of time, shouldn't be an issue.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
There are a few other trucks around here, but I don't think I have seen yours around.
Hook'em |
Thanks for the advice.
Hook'em |
My only tip, is that if you have nice paint, pull some towels out of the closet and wrap the frame bottoms with them, keeps the sharp metal corners from gouging anything on the way out.
I agree.... wrap the frames to keep from scratching the paint, and a set of extra hands make it a lot easier to handle going out and then back in.
gig'em ![]() ![]()
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
no real need to remove the seat from the cab unless you are of the very rotund variety
It will help to have a helper to pull the seat thru the cab, one on each end, although i have done it myself a number of times on a lifted truck, its a pita for me being 5'7" tall.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#13 |
The only thing I have done to my truck (so far) where I needed help was when I removed the bench seat.
I unbolted it, saved the bolts in a container, and had a friend get it from the passenger side as I got it from the driver's side. The seat belt bolts came out easily although I did lose a gas tank bolt head when I was removing that but no biggie. If that happens with the seat belt bolts just message us, you'll be in need of an extration or new bolt head. I might would take pictures of the way the seat belts overlap each other under the bolt is all. Good luck! |
#14 |
Make sure the seat is all the way forward so the seat track does not become a high speed knife when your knee hits the seat lever while removing said seat! Ouch!
#15 |
I find that a strong teenage boy on one end of the seat works best...he just folds his body in half at the waist and walks through the cab carrying his end while I back up with my end.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#16 |
In case the bolts are tight, hit them with some penetrating oil. It really is straight forward.
#17 |
Oh yea unbolt the front ones with the seat back then slide it forward and remove the rear bolts.
#18 |
![]() Join Date: Feb 2002
I have pulled the steering wheel and the floor-mounted shift lever, sometimes.
#19 |
This is the best advice on this thread.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#20 |
Not to hijack this thread but this weekend I am installing a stock bench seat and gettin rid of the buckets so i'll just do most of the above in reverse order.
#21 | |
Posted via Mobile Device |
#22 | |
![]() Join Date: Sep 2017
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
#23 |
