Old 07-11-2003, 01:46 PM   #1
Speedster 229
Unhappy Headers and burnt plug wires
I'm running a small block w/ Vortec heads and a HEI ignition.Have a set of coated Hooker comp headers. The 3rd plug wire back on the drivers side is a B----. All others run great with a 90 degree boot up to a wire loom running on top of the valve cover. The only way I can route the problem plug is straight out and over the header to the loom with a heat sheild sock in it. I'd like to run a good set of wires and was wondering if anyone knows of a set that come with more than one boot style so I could build 7 w/ 90 degree boots and one with the straight boot. Anyone else have this problem?? Heating or bending the header is out because they are coated.
1970 1/2 ton LWB 350 / 700R Rebuilt top to bottom. Not custom, but really sanitary!!!!!!!!
Speedster 229 is offline   Reply With Quote
Old 07-11-2003, 01:54 PM   #2
69sixpackbee
Get the MSD wires. They have bendable boots so you can make 'em the way you want.
69sixpackbee is offline   Reply With Quote
Old 07-11-2003, 01:56 PM   #3
Speedster 229
I'm running MSD now but must have wrong ones. Do you know a model ##. I can't tell which ones are which. Thanks
Old 07-11-2003, 02:04 PM   #4
69sixpackbee
Jeg's #121-3118 or 121-31183
http://www.jegs.com/cgi-bin/ncommerc...53&prmenbr=361
Old 07-11-2003, 02:27 PM   #5
chaptr2
chaptr2's Avatar
I use MSD wires and Coated Hooker super comp headers to with out any problem. Here is what I'm using. Just a little more info, the wire looms I'm using make it easy to twist the wire out of the way so they don't come close to the header.
Here is a couple of pics and part numbers. MSD "Under header" plug wires and the RNM-1101P wire looms. The wires are for points style cap and 90 degree boots at both ends.
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 07-11-2003, 02:29 PM   #6
chaptr2
chaptr2's Avatar
Here is the other side.
Old 07-11-2003, 02:31 PM   #7
chaptr2
chaptr2's Avatar
Here is a front shot of what the wires look like.
Plus I like showing my engine off
