I have 383 with stock 350 heads 625 cfm demon carb 204/ 214 or 224 ? @ .050, .420"-.442" 112 lsa cam with TH350 and power brakes.So I have timing set to 0* with vac line pulled as of right now my timing markers only go to 14 or 16* advance and I am not going to worm my way in there to some how mount a wider degree marker to block. I am pulling 12*-14* on vac advance from what I can tell. So from what I read 36* total time is what I need. That would put me 24*-22* idle timing. Since my markers dont go high enough and I don't want to ruin my engine how should I time vehicle?
Vac timing comes to mind @0* I am right about 10-12 lbs of vac. I am unsure how to vacuum time a vehicle. I want to get this right and I am assuming all other fuel portions are within tune what options are there or how do I time it?
Project Fast 'n' Loud
72' C10 SWB Fleet, Faux Patina, 383 ci stroker The Page: http://67-72chevytrucks.com/vboard/s...d.php?t=608214 |
![]() Join Date: Dec 2012
Re: Another timing question.
Get a timing light with an advance dial on it and use the 0° mark.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
I don't have the extra cash to get another light from what I see they are bout $100 just dont have that to drop right now but I appreciate info didn't think of that but just can't afford it. Is there any other options?
Do it the redneck way then.... that is keep advancing, test drive and when you get detonation, back off a little. Or at least use a vacuum guage.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
How about timing tape?
Just get under the truck. Clean the balancer and measure the balancer diameter. You can stick something like THIS on it.
